Rotator works correctly over the LAN , not with SATNOG client
Hello (again),
Since there is no local serial rotator support, one of the suggested work arounds is a remote rotator install. This went well and I can operate ROTCTL from the pi that has the SN client installed. However, it will not operate through the client.
Error when the observation kicks off
AttributeError: module ‘Hamlib’ has no attribute ‘-M202’
Ive tried 202, 2, -M202… same error.
Thank you in advance.
Tim
*******Generating support report. Please wait…
“versions”: {
“satnogs-client”: “unknown”,
“satnogs-ansible”: “unknown”,
“satnogs-flowgraphs”: “unknown”,
“gr-satnogs”: “unknown”,
“gr-soapy”: “unknown”,
“gnuradio”: “unknown”,
“satnogs-config”: “1.0”
“state”: {
“is-applied”: false,
“pending-tags”: null
“system”: {
“date”: “2025-04-02T18:22:49.920402+00:00”,
“platform”: {
“system”: “Linux”,
“node”: “satnogs-config”,
“release”: “6.6.51+rpt-rpi-v8”,
“version”: “#1 SMP PREEMPT Debian 1:6.6.51-1+rpt3 (2024-10-08)”,
“machine”: “aarch64”,
“processor”: “”
“memory”: {
“total”: 8331051008,
“available”: 7971065856,
“percent”: 4.3,
“used”: 262582272,
“free”: 7243288576,
“active”: 644964352,
“inactive”: 314568704,
“buffers”: 51412992,
“cached”: 773767168,
“shared”: 1875968,
“slab”: 73580544
“disk”: {
“total”: 30649761792,
“used”: 7538753536,
“free”: 21535367168,
“percent”: 25.9
“configuration”: {
“hamlib_utils_rot_enabled”: true,
“hamlib_utils_rot_opts”: “-r 10.0.0.12:4533”,
“satnogs_antenna”: “RX”,
“satnogs_lo_offset”: “100e3”,
“satnogs_log_level”: “DEBUG”,
“satnogs_rf_gain”: “49.6”,
“satnogs_rig_ip”: “satnogs_rigctld”,
“satnogs_rot_enabled”: true,
“satnogs_rot_model”: “202”,
“satnogs_rot_port”: “10.0.0.12:4533”,
“satnogs_scheduler_log_level”: “DEBUG”,
“satnogs_station_elev”: “483”,
“satnogs_station_id”: “3990”,
“satnogs_station_lat”: “45.581”,
“satnogs_station_lon”: “-89.5”
If I remember correctly, it needs these two parameters
SATNOGS_ROT_MODEL=ROT_MODEL_NETROTCTL
SATNOGS_ROT_PORT=<remote ip addres>:4533
Thanks for the response
IP and Port already
Ill add the=ROT_MODEL_NETROTCTL and report back
Tim
That was it… I did not see that pop up in any searches.
Thanks again
