Hi to all, i want to know if exist any kit, for the rotator v3 (all the parts without the printed parts). I´m have several problems to get all the pieces here in Argentina, and maybe exist a kit, to request all the parts together.
There isn’t a kit at the moment. Which parts are you having trouble with? I got most of mine from eBay apart from the t-slot (which was very expensive).
One of our group made a set of PCB’s (I have used dirty pcb’s before and they are quite reliable)
The total price for all beams already cut to size is below 11eur. Price for corners is 50/100pc so in total can be as low total as 36 per build if you split the corners which are imho the most expensive part.
Have you found a better price for corners on alibaba? Can you order at motedis or do they not ship to you?
