Rotator 360 ° problem
Hello everyone
I just had a problem on my rotator during my first tests.
I made several observations afterwards and I noticed the next day that the rotator had passed the 360 ° several times.
The result is that the cable has finally gotten stuck pulling the connection to the controller board.
Is there a solution? for example, to return the rotator to position 0 0 between two observations or another solution?
Thank you for your help and forgiveness for my english.
Regards
Manu F4HSE
hello @manu
maybe the problem it’s endstop , check connection and position of part C1041-1 .
Thank you for the answer.
For info I use a magnetic sensor instead of the mechanical sensor.
I’ll check it all this weekend
Manu
