I’ve found that when mounting the end stop switch to the End Stop Switch Mount (C1042-1) that the switch arm can bind against the mount, because there’s no clearance.
This is solved by using 2x m3 washers between the switch and the mount, which gives enough clearance to prevent any binding.
