Schedule for next transmission: 2024-08-27 (Tuesday) 10:06 UTC (again).
The closest to 10:14:36 I found is
2024-08-26 10:14:24|A49EA68AB262E0A49EA68AB2626303F03101FFFF556E652045636F6C6520706F7572206C61205669650000000000000000008C55CC6600000000A00003CA000000|10107952|Drachten-JO33bc
A000 marks the temperature as a 2 bit signed integer in little endian according to the decoder. It means you have to read the hexadecimal number as 00 A0 which is as a decimal number 160.
Inspecting the temperature panel on RoseyCubesat-1’s dashboard it reveals in line 66:
“query”: "SELECT last("temperature")/100 …
So you have to divide 160 by 100 and that’s 1.6.
The unit of the temperature panel is °C, therefore it’s 1.6 °C.
Thank you. Yeah that is a bit more sensible. I thought it was a result of atmospheric drag but i guess its not that low just yet.
Jomjom79
I think that will be getting hotter soon with its rate of decay
I’ve compiled some observations into one photo.
Would love to know how that was done, I presume you compiled the hex data into one file and then converted it into the image.
This is more straightforward. I’m not that good
I simply downloaded all the observations as audio files and played them by vlc.
I fed the signal from VLC to the soundmodem via virtual cables and started the decoder.
Fortunately, the packets are numbered and each packet, when it appeared- appeared in its appropriate place in the picture slowly filling it up.
2024-08-27 10:08:30 UTC
MaxEl 6°
Max El. 63°
This is what we get from yesterday’s and today’s database entries.
Schedule for next transmission: 2024-08-29 (Thursday) 09:51 UTC.
No packet photo data.
Next and probably last photo transmission: also today (Thursday) 23:34 UTC
There was only a 8 seconds lasting (around 77 packets) transmission at 23:38:33 UTC with some other beacons before and after.
Quite likely the last schedule for image transmission: Today (Friday) 23:18 UTC
no chance for me the El will only be 11°
2024-08-30 23:2x UTC
~1270 packets
