Rise/Set bearings vs polar plots
Hello
I have noticed, that quite often bearings for rising are not corresponding polar plots. On example below satellite rise bearing is indicated as 24°, where it clearly should be somewhere in the region of 190°-200° .
satnog_rise_set_polar
On most occasions calculations seem to be ok, but on rare ones they are quite a bit off. I have noticed that especially for rise and can’t remember if I have seen it for set.
Jed SQ2DK
Thanks for reporting!
This is a known bug, you can check its progress in https://gitlab.com/librespacefoundation/satnogs/satnogs-network/issues/479
