Hi everybody!
I’m part of the RHOK-SAT CubeSat team. Unfortunately, we haven’t been able to establish comms with our satellite (we suspect there may be issues with our ground station), and, though it’s had a short life, it is now close to re-entry. We are wondering if anyone would be interested in pinging it via a command that we would provide as a burst recording or data packet, as a last attempt to determine the satellite’s status. Regulations-wise, the satellite operates under both amateur and experimental authority, and any licensed amateur radio operator can transmit to it under the authority of their own personal amateur license.
These are the basic details:
- Uplink:
- VHF
- FSK-G3RUH modulation
- 9600 bps data rate
- Downlink:
- UHF
- BPSK-G3RUH modulation
Part of the challenge lies in the fact that we are not confident that RHOK-SAT corresponds to OBJECT-XT (NORAD ID 66907), which is what is tracked on SatNOGS. We launched on NG-23, alongside five other CubeSats: CU-ALPHA, ContentCube, EagleSat-2, Foras Promineo, and SilverSat (shout-out to the SilverSat team, who have been incredibly supportive and helpful during this process). Like RHOK-SAT, four other of these satellites have not been confirmed on Space-Track. Thus, we suspect that RHOK-SAT could be any of those. Our main candidates, which RHOK-SAT deployed together with, are:
- OBJECT-XU (NORAD ID 66908; corresponds to CU-ALPHA on SatNOGS. The satellite makes use of a satellite constellation for comms, which makes precise tracking difficult. However, its team narrowed its position to that of either 66907 or 66908.)
- OBJECT-XY (NORAD ID 66912; corresponds to ContentCube on SatNOGS. We believe that comms have not been established.)
The remaining two candidates, which deployed 90 minutes (or, one orbit) after us, are:
- OBJECT-XW (NORAD ID 66910; corresponds to EagleSat-2 on SatNOGS. We believe that comms have not been established.)
- OBJECT-XX (NORAD ID 66911; corresponds to Foras Promineo on SatNOGS. The satellite makes use a satellite constellation for comms, which makes precise tracking difficult. However, its team more closely matched its position to this object over XW.)
I don’t believe it’s likely that RHOK-SAT corresponds to XW or XX, given the deployment timing; however, since 90 minutes closely corresponds to the duration of one orbit, perhaps they could have ended up overlapping(?). I do not know how NORAD identification works.
Thank you for your consideration!
