RHCP vs LHCP in UHF Band
I’m considering upgrading my setup from a RTL-SDR blog V-dipole VHF antenna to an antennas.us QFH UHF antenna, both to improve reception from my apartment balcony and to have more passes. I see antennas.us sells antennas with RHCP and LHCP orientation. Which antenna polarization should I be looking at?
Hi @notcaptpicard,
when I was looking for which version to build I came to conclusion that better option is RHCP as this looks like most common thing, at least for the objects at LEO.
Also if you look on the turnstiles in the antenna section Antennas - SatNOGS Wiki you’ll see there RHCP ones.
Grzegorz
