I had seen some documentation on the Resourcesat 2A and it seems that it is not FM. How is it that FM telemetry is observed instead of the possible combinations as mentioned?
I had a few queries about this. I already checked n2yo.com and db.satnogs.org, but did not find out why.
Please help me figure this out.
FM is the default mode we use in DB when we don’t know the right modulation. This will be changed in the future.
If you know the right modulation please suggest the change in DB, check here how. If you are not sure and you want to experiment, then you can also add a suggestion but you need also to set the flag(yes/no field) unconfirmed
to yes
Thank you for the reply.
