[RESOLVED] New Install i can't use rtlsdr
Hello friends:
I made a new install of my #255 ground station.
I have selected rtlsdr on satnogs-setup but client doesn’t use it.
It continues trying to use audio driver.
Why?
“versions”: {
“satnogs-client”: “1.8.1”,
“gr-satnogs”: “2.3.3.0-1”,
“gr-soapy”: “2.1.3.1-1”,
“gnuradio”: “3.8.2.0-14”,
“satnogs-config”: “0.13.2”
“state”: {
“is-applied”: true,
“pending-tags”: null
“system”: {
“date”: “2022-12-19T20:12:48.140195+00:00”,
“distribution”: {
“RELEASE”: “11”,
“CODENAME”: “bullseye”,
“ID”: “Raspbian”
“pending-updates”: false,
“platform”: {
“system”: “Linux”,
“node”: “raspberrypi”,
“release”: “5.10.103-v7+”,
“version”: “#1529 SMP Tue Mar 8 12:21:37 GMT 2022”,
“machine”: “armv7l”
“memory”: {
“total”: 968052736,
“available”: 769974272,
“percent”: 20.5,
“used”: 139837440,
“free”: 226357248,
“active”: 366444544,
“inactive”: 316829696,
“buffers”: 44023808,
“cached”: 557834240,
“shared”: 618496,
“slab”: 38522880
“disk”: {
“total”: 61232377856,
“used”: 7858749440,
“free”: 50851659776,
“percent”: 13.4
“configuration”: {
“satnogs_antenna”: “RX”,
“satnogs_soapy_rx_device”: “rtlsdr”,
“satnogs_station_elev”: “120”,
“satnogs_station_id”: “255”,
“satnogs_station_lat”: “38.2768”,
“satnogs_station_lon”: “-0.6711”
And more info:
SoapySDRUtil --probe
Probe device
– Device identification
driver=Audio
hardware=Audio
device_id=0
origin=GitHub - pothosware/SoapyAudio: Soapy SDR plugin for Audio devices
– Peripheral summary
Channels: 1 Rx, 0 Tx
Timestamps: NO
Other Settings:
* Stereo Sample Offset - Offset stereo samples for off-by-one audio inputs.
[key=sample_offset, default=0, type=string, options=(-2, -1, 0, 1, 2)]
* Rig Control - Select hamlib rig control type.
[key=rig, type=string, options=(29001, 25016, 25017, 25013, 25018, 5008, 5006, 5005, 5004, 5014, 5003, 5015, 5002, 5001, 5013, 5016, 17001, 17002, 25006, 32001, 25003, 23003, 23004, 31002, 31001, 9002, 9003, 33001, 2021, 2029, 2043, 2047, 2044, 2045, 2038, 25001, 25007, 4, 25012, 23001, 2036, 2048, 25015, 1, 6, 2, 2046, 25019, 3054, 3002, 3003, 3072, 3004, 3006, 3007, 3060, 3055, 3085, 3009, 3010, 3011, 3012, 3070, 3013, 3061, 3014, 3015, 3016, 3017, 3073, 3019, 3020, 3021, 3022, 3067, 3023, 3046, 3024, 3026, 3027, 3047, 3057, 3063, 3028, 3078, 3029, 3062, 3030, 3045, 3056, 3031, 3075, 3032, 3034, 3044, 3068, 3065, 3035, 3081, 30001, 30003, 30002, 30004, 4002, 4001, 4003, 4004, 3036, 3058, 3080, 3077, 3040, 3037, 3041, 3038, 3039, 3079, 3043, 3066, 3069, 3042, 3083, 3082, 3084, 3071, 6005, 6006, 6007, 25011, 18001, 2015, 2033, 2042, 2017, 2019, 2020, 2023, 2026, 2034, 2027, 2030, 2025, 2014, 2002, 2003, 2028, 2001, 2004, 2016, 2031, 2037, 2024, 2005, 2006, 2007, 2008, 2009, 2010, 2041, 2022, 2011, 2012, 2013, 2039, 10004, 3074, 25014, 2040, 3053, 3052, 28001, 24001, 11005, 11003, 8004, 27002, 27001, 27003, 25002, 2032, 14004, 14002, 25009, 22001, 5, 3064, 3051, 16003, 16012, 16004, 16005, 16007, 16002, 16001, 16008, 16009, 16011, 16013, 8002, 8006, 8001, 8003, 8012, 8010, 8011, 1033, 26001, 26002, 12004, 15001, 15002, 15003, 15004, 15005, 15006, 15007, 15009, 3076, 1017, 1019, 1018, 1021, 1003, 1024, 1029, 1027, 1039, 1010, 1005, 1006, 1007, 1009, 1020, 1041, 1011, 1001, 1038, 1022, 1015, 1036, 1023, 1013, 1014, 1028, 1031, 1016, 1035, 1034, 1037, 1032, 1030, 1040, 1004, 1025, 1026, 25008)]
* Rig Serial Rate - Select hamlib rig serial control rate.
[key=rig_rate, default=57600, type=string, options=(1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200, 128000, 256000)]
* Rig Serial Port - hamlib rig Serial Port dev / COMx / IP-Address
[key=rig_port, default=/dev/ttyUSB0, type=string]
– RX Channel 0
Full-duplex: YES
Supports AGC: YES
Native format: CS16 [full-scale=65536]
Stream args:
* Channel Setup - Input channel configuration.
[key=chan, default=mono_l, type=string, options=(mono_l, mono_r, stereo_iq, stereo_qi)]
Antennas: RX
Full gain range: [0, 0] dB
Full freq range: [0, 6000] MHz
RF freq range: [0, 6000] MHz
Sample rates: 0.008, 0.016, 0.02205, 0.032, 0.0441, 0.048, 0.096 MSps
And info from log:
Dec 19 20:51:16 raspberrypi satnogs-client[1352]: rig_init: rig does not have rx_range!!
Dec 19 20:51:16 raspberrypi satnogs-client[1352]: network_open: hoststr=127.0.0.1, portstr=4532
Dec 19 20:51:18 raspberrypi satnogs-client[2601]: [INFO] [UHD] linux; GNU C++ version 10.2.1 20210110; Boost_107400; UHD_3.15.0.0-4+b1satnogs1
Dec 19 20:51:19 raspberrypi satnogs-client[2601]: Found Rafael Micro R820T tuner
Dec 19 20:51:19 raspberrypi satnogs-client[2601]: Traceback (most recent call last):
Dec 19 20:51:19 raspberrypi satnogs-client[2601]: File “/usr/bin/satnogs_amsat_fox_duv_decoder.py”, line 515, in
Dec 19 20:51:19 raspberrypi satnogs-client[2601]: main()
Dec 19 20:51:19 raspberrypi satnogs-client[2601]: File “/usr/bin/satnogs_amsat_fox_duv_decoder.py”, line 498, in main
Dec 19 20:51:19 raspberrypi satnogs-client[2601]: tb = top_block_cls(antenna=options.antenna, bb_freq=options.bb_freq, bw=options.bw, dc_removal=options.dc_removal, decoded_data_file_path=options.decoded_data_file_path, dev_args=options.dev_args, doppler_correction_per_sec=options.doppler_correction_per_sec, enable_iq_dump=options.enable_iq_dump, file_path=options.file_path, gain=options.gain, gain_mode=options.gain_mode, iq_file_path=options.iq_file_path, lo_offset=options.lo_offset, other_settings=options.other_settings, ppm=options.ppm, rigctl_port=options.rigctl_port, rx_freq=options.rx_freq, samp_rate_rx=options.samp_rate_rx, soapy_rx_device=options.soapy_rx_device, stream_args=options.stream_args, tune_args=options.tune_args, udp_IP=options.udp_IP, udp_dump_host=options.udp_dump_host, udp_dump_port=options.udp_dump_port, udp_port=options.udp_port, waterfall_file_path=options.waterfall_file_path)
Dec 19 20:51:19 raspberrypi satnogs-client[2601]: File “/usr/bin/satnogs_amsat_fox_duv_decoder.py”, line 92, in init
Dec 19 20:51:19 raspberrypi satnogs-client[2601]: self.soapy_source_0_0 = soapy.source(1, dev, dev_args, stream_args,
Dec 19 20:51:19 raspberrypi satnogs-client[2601]: File “/usr/lib/python3/dist-packages/soapy/soapy_swig.py”, line 131, in make
Dec 19 20:51:19 raspberrypi satnogs-client[2601]: return _soapy_swig.source_make(nchan, device, dev_args, stream_args, tune_args, other_settings, sampling_rate, type)
Dec 19 20:51:19 raspberrypi satnogs-client[2601]: RuntimeError: soapy::source: Unsupported sample rate (2048000.000000). Rate must be in the range [8000.000000, 8000.000000] [16000.000000, 16000.000000] [22050.000000, 22050.000000] [32000.000000, 32000.000000] [44100.000000, 44100.000000] [48000.000000, 48000.000000] [96000.000000, 96000.000000]
Dec 19 20:51:21 raspberrypi satnogs-client[1352]: netrigctl_close: done status=Command completed successfully
Dec 19 20:51:22 raspberrypi satnogs-client[1352]: satnogsclient.observer.observer - ERROR - No waterfall data file found
And more info:
root@raspberrypi:/home/pi# SoapySDRUtil --probe=“driver=rtlsdr”
Probe device driver=rtlsdr
[INFO] Opening Generic RTL2832U OEM :: 00000001…
driver=RTLSDR
hardware=R820T
index=0
origin=GitHub - pothosware/SoapyRTLSDR: SoapySDR RTL-SDR Support Module
Timestamps: YES
Time sources: sw_ticks
Other Settings:
* Bias Tee - RTL-SDR Blog V.3 Bias-Tee Mode
[key=biastee, default=false, type=bool]
– RX Channel 0
Full-duplex: NO
Supports AGC: YES
Stream args:
Antennas: RX
Full gain range: [0, 49.6] dB
RF freq range: [24, 1764] MHz
Filter bandwidths: [0, 8] MHz
This should be driver=rtlsdr
If this doesn’t solve the issues you have, re-post any logs.
For example now you have this error:
This says that the selected sample rate isn’t supported, however by using the right sdr by changing the value above, this sample rate issue may be solved.
A lot of thank’s for your reply.
Changed to driver=rtlsdr but problem continues:
“versions”: {
“state”: {
“is-applied”: true,
“system”: {
“date”: “2022-12-19T21:43:37.398481+00:00”,
“distribution”: {
“RELEASE”: “11”,
“ID”: “Raspbian”
“platform”: {
“system”: “Linux”,
“machine”: “armv7l”
“memory”: {
“total”: 968052736,
“available”: 695902208,
“percent”: 28.1,
“used”: 204787712,
“free”: 388710400,
“active”: 255844352,
“inactive”: 261959680,
“buffers”: 40628224,
“cached”: 333926400,
“shared”: 11083776,
“slab”: 36233216
“disk”: {
“used”: 7889756160,
“free”: 50820653056,
“percent”: 13.4
“configuration”: {
can you copy paste the more recent logs from journalctl?
Also set the SATNOGS_RF_GAIN, a good starting point is the value 32.8
Solved … I don’t know how, but it has been solved.
A lot of thank’s !!!
Hello ,having problems with rtlsdr sample rate
I have gone through same steps mine still does not work ,is this still an issue ,i will get log files and upload
Please share some details and maybe we can help you.
Hi , Thanks for response
Blockquote
“versions”: {
“gr-satnogs”: “2.3.5.0-1”,
“state”: {
“is-applied”: true,
“system”: {
“date”: “2024-03-03T11:52:49.543016+00:00”,
“distribution”: {
“RELEASE”: “11”,
“ID”: “Raspbian”
“platform”: {
“system”: “Linux”,
“node”: “satnog”,
“release”: “6.1.21-v7+”,
“version”: “#1642 SMP Mon Apr 3 17:20:52 BST 2023”,
“machine”: “armv7l”
“memory”: {
“total”: 966750208,
“available”: 795254784,
“percent”: 17.7,
“used”: 115023872,
“free”: 479551488,
“active”: 100175872,
“inactive”: 324395008,
“buffers”: 31535104,
“cached”: 340639744,
“shared”: 794624,
“slab”: 35631104
“disk”: {
“total”: 30436458496,
“used”: 4043350016,
“free”: 25102217216,
“percent”: 13.9
“configuration”: {
“satnogs_log_level”: “DEBUG”,
“satnogs_rf_gain”: “38.2”,
“satnogs_rx_samp_rate”: “2.048”,
“satnogs_soapy_rx_device”: “device=rtlsdr”,
“satnogs_station_elev”: “5”,
“satnogs_station_id”: “3476”,
“satnogs_station_lat”: “-33.783”,
“satnogs_station_lon”: “18.463”
devmonk@satnog:~ $ SoapySDRUtil --find=driver=rtlsdr
Found device 0
driver = rtlsdr
label = Generic RTL2832U OEM :: 00000001
manufacturer = Realtek
product = RTL2838UHIDIR
serial = 00000001
tuner = Rafael Micro R820T
devmonk@satnog:~ $ SoapySDRUtil --probe=driver=rtlsdr
driver=RTLSDR
hardware=R820T
index=0
Timestamps: YES
Other Settings:
– RX Channel 0
Full-duplex: NO
Supports AGC: YES
Stream args:
Antennas: RX
Mar 03 12:04:29 satnog satnogs-client[1217]: satnogsclient.observer.orbital - DEBUG - Calculated data: {‘alt’: 0.18702398240566254, ‘az’: 0.20225323736667633, ‘rng’: 1624537.75, ‘rng_vlct’: -7015.1904296875, ‘ok’: True}
Mar 03 12:04:29 satnog satnogs-client[1217]: satnogsclient.observer.worker - DEBUG - Initial frequency: 437128700
Mar 03 12:04:29 satnog satnogs-client[1217]: satnogsclient.observer.worker - DEBUG - Rigctld msg: 437138928
Mar 03 12:04:29 satnog satnogs-client[1574]: Traceback (most recent call last):
Mar 03 12:04:29 satnog satnogs-client[1574]: File “/usr/bin/satnogs_fsk.py”, line 544, in
Mar 03 12:04:29 satnog satnogs-client[1574]: main()
Mar 03 12:04:29 satnog satnogs-client[1574]: File “/usr/bin/satnogs_fsk.py”, line 527, in main
Mar 03 12:04:29 satnog satnogs-client[1574]: tb = top_block_cls(antenna=options.antenna, baudrate=options.baudrate, bb_freq=options.bb_freq, bw=options.bw, dc_removal=options.dc_removal, decoded_data_file_path=options.decoded_data_file_path, dev_args=options.dev_args, doppler_correction_per_sec=options.doppler_correction_per_sec, enable_iq_dump=options.enable_iq_dump, file_path=options.file_path, framing=options.framing, gain=options.gain, gain_mode=options.gain_mode, iq_file_path=options.iq_file_path, lo_offset=options.lo_offset, other_settings=options.other_settings, ppm=options.ppm, rigctl_port=options.rigctl_port, rx_freq=options.rx_freq, samp_rate_rx=options.samp_rate_rx, soapy_rx_device=options.soapy_rx_device, stream_args=options.stream_args, tune_args=options.tune_args, udp_IP=options.udp_IP, udp_dump_host=options.udp_dump_host, udp_dump_port=options.udp_dump_port, udp_port=options.udp_port, waterfall_file_path=options.waterfall_file_path)
Mar 03 12:04:29 satnog satnogs-client[1574]: File “/usr/bin/satnogs_fsk.py”, line 97, in init
Mar 03 12:04:29 satnog satnogs-client[1574]: self.soapy_source_0_0 = soapy.source(1, dev, dev_args, stream_args,
Mar 03 12:04:29 satnog satnogs-client[1574]: File “/usr/lib/python3/dist-packages/soapy/soapy_swig.py”, line 131, in make
Mar 03 12:04:29 satnog satnogs-client[1574]: return _soapy_swig.source_make(nchan, device, dev_args, stream_args, tune_args, other_settings, sampling_rate, type)
Mar 03 12:04:29 satnog satnogs-client[1574]: RuntimeError: soapy::source: Unsupported sample rate (2.048000). Rate must be in the range [8000.000000, 8000.000000] [16000.000000, 16000.000000] [22050.000000, 22050.000000] [32000.000000, 32000.000000] [44100.000000, 44100.000000] [48000.000000, 48000.000000] [96000.000000, 96000.000000]
Mar 03 12:04:29 satnog satnogs-client[1217]: satnogsclient.observer.orbital - DEBUG - Observer data: {‘lon’: 18.463, ‘lat’: -33.783, ‘elev’: 5}
Mar 03 12:04:29 satnog satnogs-client[1217]: satnogsclient.observer.orbital - DEBUG - Satellite data: {‘tle0’: ‘0 CELESTIS 21 - VARISAT 1C’, ‘tle1’: ‘1 52766U 22057AL 24063.07352244 .00016719 00000-0 63067-3 0 9993’, ‘tle2’: ‘2 52766 97.5674 186.5996 0010736 142.2453 217.9541 15.27068660 98230’}
Mar 03 12:04:29 satnog satnogs-client[1217]: satnogsclient.observer.orbital - DEBUG - Calculated data: {‘alt’: 0.18731026351451874, ‘az’: 0.20223762094974518, ‘rng’: 1623502.875, ‘rng_vlct’: -7014.794921875, ‘ok’: True}
Here are some logs from soapySDRUtil as well as
journalctl -f -u satnogs-client.service
Hope you can help , awesome project , would be great to get it working
Thanks
Eric
change “satnogs_rx_samp_rate”: “2.048”" with “satnogs_rx_samp_rate”: “2.048e6”"
you are missing e6
Hi , Thanks but I tried before , doesn’t work , seems to think its another SDR , or sound card that someone mentioned ?
I see that you have a docker image is that a better way , maybe better way to debug python ?
Blockquote
Mar 03 15:18:57 satnog satnogs-client[2193]: satnogsclient.observer.worker - DEBUG - Rigctld msg: 437494219
Mar 03 15:18:57 satnog satnogs-client[2248]: Traceback (most recent call last):
Mar 03 15:18:57 satnog satnogs-client[2248]: File “/usr/bin/satnogs_cw_decoder.py”, line 489, in
Mar 03 15:18:57 satnog satnogs-client[2248]: main()
Mar 03 15:18:57 satnog satnogs-client[2248]: File “/usr/bin/satnogs_cw_decoder.py”, line 472, in main
Mar 03 15:18:57 satnog satnogs-client[2248]: tb = top_block_cls(antenna=options.antenna, bb_freq=options.bb_freq, bfo_freq=options.bfo_freq, bw=options.bw, dc_removal=options.dc_removal, decoded_data_file_path=options.decoded_data_file_path, dev_args=options.dev_args, doppler_correction_per_sec=options.doppler_correction_per_sec, enable_iq_dump=options.enable_iq_dump, file_path=options.file_path, gain=options.gain, gain_mode=options.gain_mode, iq_file_path=options.iq_file_path, lo_offset=options.lo_offset, other_settings=options.other_settings, ppm=options.ppm, rigctl_port=options.rigctl_port, rx_freq=options.rx_freq, samp_rate_rx=options.samp_rate_rx, soapy_rx_device=options.soapy_rx_device, stream_args=options.stream_args, tune_args=options.tune_args, udp_IP=options.udp_IP, udp_dump_host=options.udp_dump_host, udp_dump_port=options.udp_dump_port, udp_port=options.udp_port, waterfall_file_path=options.waterfall_file_path, wpm=options.wpm)
Mar 03 15:18:57 satnog satnogs-client[2248]: File “/usr/bin/satnogs_cw_decoder.py”, line 92, in init
Mar 03 15:18:57 satnog satnogs-client[2248]: self.soapy_source_0_0 = soapy.source(1, dev, dev_args, stream_args,
Mar 03 15:18:57 satnog satnogs-client[2248]: File “/usr/lib/python3/dist-packages/soapy/soapy_swig.py”, line 131, in make
Mar 03 15:18:57 satnog satnogs-client[2248]: return _soapy_swig.source_make(nchan, device, dev_args, stream_args, tune_args, other_settings, sampling_rate, type)
Mar 03 15:18:57 satnog satnogs-client[2248]: RuntimeError: soapy::source: Unsupported sample rate (2048000.000000). Rate must be in the range [8000.000000, 8000.000000] [16000.000000, 16000.000000] [22050.000000, 22050.000000] [32000.000000, 32000.000000] [44100.000000, 44100.000000] [48000.000000, 48000.000000] [96000.000000, 96000.000000]
Sorry, missed another configuration error.
Change soapy-rx-device: "device=rtlsdr with soapy-rx-device: "driver=rtlsdr
