Repository no longer has Release File - Raspbian_11
Currently running Satnogs 1.8.1 on RPi 3B.
On March 4, 2024, the repository in the /etc/apt/sources.list.d/satnogs.list stopped working with apt-get.
pi@satnogs:/ $ sudo apt-get update
Ign:1 http://download.opensuse.org/repositories/home:/librespace:/satnogs/Raspbian_11 ./ InRelease
Hit:2 http://ppa.launchpad.net/ansible/ansible/ubuntu focal InRelease
Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
Hit:4 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
Get:5 https://deb.nodesource.com/node_16.x bullseye InRelease [4,586 B]
Get:6 https://pkgs.tailscale.com/stable/raspbian bullseye InRelease
Err:7 http://download.opensuse.org/repositories/home:/librespace:/satnogs/Raspbian_11 ./ Release
  404  Not Found [IP: 195.135.223.226 80]
Reading package lists... Done
E: The repository 'http://download.opensuse.org/repositories/home:/librespace:/satnogs/Raspbian_11 ./ Release' no longer has a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
It appears that on that day, the URL is no longer valid:
Poking around on opensuse.org, it looks like it has changed to:
http://download.opensuse.org/repositories/home:/librespace:/satnogs/Debian_11/
Can the satnogs.list be update to the new URL without issue, or, will it be updated automatically?
Hello,
The Raspbian repositories have been removed and the next release will be using Docker. New packages will not be published on the Raspbian repositories any more so you can safely remove these repos.
Can you expand on this change to Docker and how stations should prepare for this change?
Will there be a conversion or a migration of some kind to a Docker container?
I’m asking because I am building a new RPi ground station.
Thank you
Hi, I have just clean installed latest version of satnogs as the one I was running for years now was on buster and I have failed with migration to bullseye. I have the same issue with opensuse repo. Can we get more info on that docker thingy and any timeline?
I understand that there will be a change but when and how do we upgrade from what we have now?
73s
It should be possible to use the regular debian repos there, just not the raspbian ones. the packages are built for armhf and arm64 so should work just fine on 32 or 64bit raspberry pi os. not sure what the status on the image is.
go for it.
