Regarding artifacts and Decoded Data in DTUSAT-2
I have a doubt about observations similar to this: SatNOGS Network - Observation 4277140.
Is there any artifact data available for good observations in DTUSAT-2?
How to use Artifact data to reverse engineer GNU Radio flowgraphs?
Is there any decoded data available for DTUSAT2?
Hi @ratczsar and welcome in the community!
Not sure if there are good data from DTUSAT-2, the only one I see that could be a good candidate is https://network.satnogs.org/observations/250006/ but I’m not 100% sure.
Specifically for the observation you linked, there isn’t any visible signal, except if I miss something, that follow a vertical line near or at the center of the waterfall, for this reason I would change it to bad. For vetting and the expected signal curve please check this guide.
