Hi!
After the update of Satnogs ground stations, I noticed a significant reduction in the signal power that my ground station collects. Should I change something in the settings of my antenna (like gain)? Here is an example of one of my observations: https://network.satnogs.org/observations/2101597/
I’m not sure the default gain is meaningful anymore. I suspect it might be zero.
Follow the “Setting a gain” guide to find a suitable gain value for your station: https://wiki.satnogs.org/Omnidirectional_Station_How_To#Setting_the_gain
73
Mark VK5QI
Thank you so much! I will try that!
