need some advice what might be wrong.
The error condition is as follows:
Recording starts as scheduled and an ogg file is created:
root 1638 1525 1 23:05 ? 00:00:07 oggenc --raw-endianness=0 -r -B 16 -q 4 -C 1 -R 24000 -
root 1640 1525 2 23:05 ? 00:00:18 rtl_fm -M fm -g 40 -f 145825000 -p 52.0 -s 22050
drwxr-xr-x 4 root root 4096 Aug 7 23:05 ./
drwxrwxrwt 5 root root 4096 Aug 7 23:17 …/
drwxr-xr-x 2 root root 4096 Aug 7 23:09 complete/
drwxr-xr-x 2 root root 4096 Aug 7 21:34 incomplete/
-rw-r–r-- 1 root root 3878912 Aug 7 23:17 receiving_satnogs_640_2015-08-07T21-05-39.ogg
root@oe6xug-satnogs:/tmp/.satnogs#
for some reason the recording doesnt stop. only killing the supervisor allowed me to stop the rtl_fm and oggenc process.
Does someone have an idea whats causing this?
br Robert
ps: did some attempts, but no job ended as scheduled
ps1: the content is correct in the file
is it possible, that i have to set machine time zone to utc?
somehow this few lines from scheduler.py is suggesting this to me:
while True:
if datetime.now(pytz.utc) < end:
time.sleep(1)
else:
receiver.stop()
break
i fetched the 0.2.3 version of the client and used the raspi2 manual to get it operational on my ubuntu dist.
but your indication was right.
my local file of receiver.py was different to the git version file.
Did a manual copy over to get the new block:
133 def stop(self):
134 “”“Stops the receiver pipelines.”""
135 logger.info(‘Stop receiver’)
136 filename = self.get_output_path(receiving=False)
137 os.rename(self.output.name, filename)
138 self.producer.kill()
139 self.consumer.kill()
140 self.output.close()
141 os.close(self.pipe[0])
142 os.close(self.pipe[1])
but i wonder what the correct precedure for update is.
this because i used pip install --update satnogs-client and hopped to get the last recent code.
Ahh ok yeah that’s it. I wasn’t sure if that fix had made it in before 0.2.3 or not. I’ll poke @johngian about rolling a new release (along with the configurable ppm)
John was too quick for me and we have this fixed in 0.2.4 now! please test this for us by upgrading with pip and ensure the bug goes away.
I am flying today but tomorrow I will update the instructions for PPM shift. You should be able to add SATNOGS_PPM_ERROR to your settings to set the ppm shift
