Hi all,
Having an issue getting my station up and running, and have spent substantial time reading and troubleshooting before this post. I’m guessing this is likely a PEBKAC issue (Problem Exists Between Keyboard And Chair), though could use some advice.
Thanks in advance.
Problem:
After installing and setting up my Pi and Satnogs client, I can schedule an observation successfully. When it comes time for the observation to run - it appears that little happens and that no observation is made.
What I Have Done
- Reinstalled image from scratch
- Tried another RPi
- Ensured that Raspbian is up to date
- Ensured that satnogs-config is updated
- Installed Satnogs Monitor - I can see the jobs come up, but when the job should be active there is no waterfall or activity
- rtl_test is successful
- /tmp/.satnogs/data temporarily has the ‘receiving_waterfall…dat’ file of 0 size
- /tmp/.satnogs/data/incomplete is empty
- Installed SoapySDR and attempted a connection with CubicSDR on Win (crashes)
- There are some kernel mismatch errors, but after investigating these appear unrelated and of no concern (common in current Raspbian)
- APPLY - Interestingly, the Apply function ALWAYS stalls and I must Ctrl-C (this occurred on both Pi’s and with different installs) - This happens on 'Download UHD images…
systemctl status satnogs-client
pi@RPi1683:/tmp/.satnogs/data $ systemctl status satnogs-client
● satnogs-client.service - SatNOGS client
Active: active (running) since Sun 2020-07-26 14:03:12 UTC; 36min ago
Main PID: 344 (satnogs-client)
Tasks: 22 (limit: 4915)
└─344 /var/lib/satnogs/bin/python3 /var/lib/satnogs/bin/satnogs-clientJul 26 14:22:38 RPi1683 satnogs-client[344]: observer.observe()
Jul 26 14:22:38 RPi1683 satnogs-client[344]: File “/var/lib/satnogs/lib/python3.7/site-packages/satnogsclient/observer/observer.py”, line 165, in
Jul 26 14:22:38 RPi1683 satnogs-client[344]: self.plot_waterfall()
Jul 26 14:22:38 RPi1683 satnogs-client[344]: File “/var/lib/satnogs/lib/python3.7/site-packages/satnogsclient/observer/observer.py”, line 267, in
Jul 26 14:22:38 RPi1683 satnogs-client[344]: waterfall_png=self.observation_waterfall_png)
Jul 26 14:22:38 RPi1683 satnogs-client[344]: File “/var/lib/satnogs/lib/python3.7/site-packages/satnogsclient/observer/waterfall.py”, line 39, in
Jul 26 14:22:38 RPi1683 satnogs-client[344]: waterfall = read_waterfall(waterfall_file)
Jul 26 14:22:38 RPi1683 satnogs-client[344]: File “/var/lib/satnogs/lib/python3.7/site-packages/satnogsclient/observer/waterfall.py”, line 22, in
Jul 26 14:22:38 RPi1683 satnogs-client[344]: ‘timestamp’: np.fromfile(wf_file, dtype=’|S32’, count=1)[0],
Jul 26 14:22:38 RPi1683 satnogs-client[344]: IndexError: index 0 is out of bounds for axis 0 with size 0
lines 1-18/18 (END)
Support File
“versions”: {
“satnogs-client”: “1.3.4”,
“satnogs-client-ansible”: “202007160921”,
“satnogs-flowgraphs”: “1.2.2-1”,
“gr-satnogs”: “2.1.2.1-1”,
“gr-soapy”: “2.1.3-1”,
“gnuradio”: “3.8.1.0~rc1-2”,
“satnogs-config”: “0.10.2”
“state”: {
“is-applied”: false,
“pending-tags”: null
“system”: {
“date”: “2020-07-26T14:27:58.968153+00:00”,
“distribution”: {
“RELEASE”: “10”,
“CODENAME”: “buster”,
“ID”: “Raspbian”
“pending-updates”: false,
“platform”: {
“system”: “Linux”,
“node”: “RPi1683”,
“release”: “5.4.51-v7l+”,
“version”: “#1327 SMP Thu Jul 23 11:04:39 BST 2020”,
“machine”: “armv7l”,
“processor”: “”
“memory”: {
“total”: 4013887488,
“available”: 3766697984,
“percent”: 6.2,
“used”: 106831872,
“free”: 3558486016,
“active”: 262766592,
“inactive”: 135737344,
“buffers”: 27209728,
“cached”: 321359872,
“shared”: 8851456,
“slab”: 31088640
“disk”: {
“total”: 15351623680,
“used”: 3667795968,
“free”: 11012694016,
“percent”: 25.0
“configuration”: {
“satnogs_antenna”: “RX”,
“satnogs_rf_gain”: “32.8”,
“satnogs_station_elev”: “195”,
“satnogs_station_id”: “1683”,
“satnogs_station_lat”: “-35.051”,
“satnogs_station_lon”: “138.605”
