Raspbian SatNOGS Image - Log Locations?-Found (& Errors..)
I’ve been working with getting a receiver online using the new rpi image. However, I seem to be having some issues connecting to the service. I’m working on 145 at present, but can’t seem to be able to get it to connect. I’ve tried all log locations in the documentation, but haven’t been able to find any useful logs.
Would it be possible to point to me where the logs are located on the Raspbian image?
Thanks,
Malcolm
I was able to find the error using journald, from the PDF documentation:
journalctl -u satnogs-client.service
However, I’m not left with an immediate answer with the results. Any feedback or guidance would be appreciated.
pi@raspberrypi:/var/log $ journalctl -u satnogs-client.service
– Logs begin at Sat 2017-09-23 16:41:32 EDT, end at Sat 2017-09-23 16:55:57 EDT
Sep 23 16:41:44 raspberrypi systemd[1]: Started SatNOGS client.
Sep 23 16:41:50 raspberrypi satnogs-client[527]: 2017-09-23 16:41:50,209 - satno
Sep 23 16:41:50 raspberrypi satnogs-client[527]: 2017-09-23 16:41:50,212 - satno
Sep 23 16:41:50 raspberrypi satnogs-client[527]: 2017-09-23 16:41:50,213 - satno
Sep 23 16:41:50 raspberrypi satnogs-client[527]: 2017-09-23 16:41:50,214 - satno
Sep 23 16:41:50 raspberrypi satnogs-client[527]: 2017-09-23 16:41:50,215 - satno
Sep 23 16:41:50 raspberrypi satnogs-client[527]: 2017-09-23 16:41:50,216 - satno
Sep 23 16:41:50 raspberrypi satnogs-client[527]: 2017-09-23 16:41:50,218 - satno
Sep 23 16:41:50 raspberrypi satnogs-client[527]: 2017-09-23 16:41:50,219 - satno
Sep 23 16:41:50 raspberrypi satnogs-client[527]: 2017-09-23 16:41:50,221 - satno
Sep 23 16:41:50 raspberrypi satnogs-client[527]: 2017-09-23 16:41:50,222 - satno
Sep 23 16:41:50 raspberrypi satnogs-client[527]: 2017-09-23 16:41:50,223 - satno
Sep 23 16:41:50 raspberrypi satnogs-client[527]: 2017-09-23 16:41:50,232 - satno
Sep 23 16:41:50 raspberrypi satnogs-client[527]: WebSocket transport not availab
Sep 23 16:41:50 raspberrypi satnogs-client[527]: * Running on http://0.0.0.0:50
Sep 23 16:41:50 raspberrypi satnogs-client[527]: 2017-09-23 16:41:50,668 - satno
Sep 23 16:42:50 raspberrypi satnogs-client[527]: 2017-09-23 16:42:50,662 - apsch
Sep 23 16:42:50 raspberrypi satnogs-client[527]: 2017-09-23 16:42:50,741 - apsch
Sep 23 16:42:50 raspberrypi satnogs-client[527]: Traceback (most recent call las
Sep 23 16:42:50 raspberrypi satnogs-client[527]: File "/var/lib/satnogs/local/
Sep 23 16:42:50 raspberrypi satnogs-client[527]: retval = job.func(*job.args
lines 1-23…skipping…
lines 1-24…skipping…
– Logs begin at Sat 2017-09-23 16:41:32 EDT, end at Sat 2017-09-23 16:55:57 EDT. –
Sep 23 16:41:50 raspberrypi satnogs-client[527]: 2017-09-23 16:41:50,209 - satnogsclient - INFO - Starting status listener thread…
Sep 23 16:41:50 raspberrypi satnogs-client[527]: 2017-09-23 16:41:50,212 - satnogsclient - INFO - Dir /tmp/.satnogs/data/files/
Sep 23 16:41:50 raspberrypi satnogs-client[527]: 2017-09-23 16:41:50,213 - satnogsclient - INFO - Made dir /tmp/.satnogs/data/files/
Sep 23 16:41:50 raspberrypi satnogs-client[527]: 2017-09-23 16:41:50,214 - satnogsclient - INFO - Check dir /tmp/.satnogs/data/files/SU_LOG
Sep 23 16:41:50 raspberrypi satnogs-client[527]: 2017-09-23 16:41:50,215 - satnogsclient - INFO - Made dir /tmp/.satnogs/data/files/SU_LOG
Sep 23 16:41:50 raspberrypi satnogs-client[527]: 2017-09-23 16:41:50,216 - satnogsclient - INFO - Check dir /tmp/.satnogs/data/files/WOD_LOG
Sep 23 16:41:50 raspberrypi satnogs-client[527]: 2017-09-23 16:41:50,218 - satnogsclient - INFO - Made dir /tmp/.satnogs/data/files/WOD_LOG
Sep 23 16:41:50 raspberrypi satnogs-client[527]: 2017-09-23 16:41:50,219 - satnogsclient - INFO - Check dir /tmp/.satnogs/data/files/EXT_WOD_LOG
Sep 23 16:41:50 raspberrypi satnogs-client[527]: 2017-09-23 16:41:50,221 - satnogsclient - INFO - Made dir /tmp/.satnogs/data/files/EXT_WOD_LOG
Sep 23 16:41:50 raspberrypi satnogs-client[527]: 2017-09-23 16:41:50,221 - satnogsclient - INFO - Made dir /tmp/.satnogs/data/files/EXT_WOD_RX
Sep 23 16:41:50 raspberrypi satnogs-client[527]: 2017-09-23 16:41:50,222 - satnogsclient - INFO - Made dir /tmp/.satnogs/data/files/WOD_RX
Sep 23 16:41:50 raspberrypi satnogs-client[527]: 2017-09-23 16:41:50,223 - satnogsclient - INFO - Made dir /tmp/.satnogs/data/files/WOD_RX_DEC
Sep 23 16:41:50 raspberrypi satnogs-client[527]: 2017-09-23 16:41:50,232 - satnogsclient - INFO - Press Ctrl+C to exit SatNOGS poller
Sep 23 16:41:50 raspberrypi satnogs-client[527]: WebSocket transport not available. Install eventlet or gevent and gevent-websocket for improved performance.
Sep 23 16:41:50 raspberrypi satnogs-client[527]: * Running on http://0.0.0.0:5000/ (Press CTRL+C to quit)
Sep 23 16:41:50 raspberrypi satnogs-client[527]: 2017-09-23 16:41:50,668 - satnogsclient - INFO - [LD] Downlink thread waiting for first downlink packet
Sep 23 16:42:50 raspberrypi satnogs-client[527]: 2017-09-23 16:42:50,662 - apscheduler.executors.default - INFO - Running job “get_jobs (trigger: interval[0:01:00], next run at: 2017-09-23 20:43:50 UTC)” (
Sep 23 16:42:50 raspberrypi satnogs-client[527]: 2017-09-23 16:42:50,741 - apscheduler.executors.default - ERROR - Job “get_jobs (trigger: interval[0:01:00], next run at: 2017-09-23 20:43:50 UTC)” raised a
Sep 23 16:42:50 raspberrypi satnogs-client[527]: Traceback (most recent call last):
Sep 23 16:42:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/apscheduler/executors/base.py”, line 125, in run_job
Sep 23 16:42:50 raspberrypi satnogs-client[527]: retval = job.func(*job.args, **job.kwargs)
Sep 23 16:42:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/satnogsclient/scheduler/tasks.py”, line 154, in get_jobs
Sep 23 16:42:50 raspberrypi satnogs-client[527]: url, params=params, headers=headers, verify=settings.SATNOGS_VERIFY_SSL)
Sep 23 16:42:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/api.py”, line 72, in get
Sep 23 16:42:50 raspberrypi satnogs-client[527]: return request(‘get’, url, params=params, **kwargs)
Sep 23 16:42:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/api.py”, line 58, in request
Sep 23 16:42:50 raspberrypi satnogs-client[527]: return session.request(method=method, url=url, **kwargs)
Sep 23 16:42:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/sessions.py”, line 494, in request
Sep 23 16:42:50 raspberrypi satnogs-client[527]: prep = self.prepare_request(req)
Sep 23 16:42:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/sessions.py”, line 437, in prepare_request
Sep 23 16:42:50 raspberrypi satnogs-client[527]: hooks=merge_hooks(request.hooks, self.hooks),
Sep 23 16:42:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/models.py”, line 305, in prepare
Sep 23 16:42:50 raspberrypi satnogs-client[527]: self.prepare_url(url, params)
Sep 23 16:42:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/models.py”, line 379, in prepare_url
Sep 23 16:42:50 raspberrypi satnogs-client[527]: raise MissingSchema(error)
Sep 23 16:42:50 raspberrypi satnogs-client[527]: MissingSchema: Invalid URL ‘jobs/’: No schema supplied. Perhaps you meant http://jobs/?
Sep 23 16:43:50 raspberrypi satnogs-client[527]: 2017-09-23 16:43:50,716 - apscheduler.executors.default - INFO - Running job “get_jobs (trigger: interval[0:01:00], next run at: 2017-09-23 20:43:50 UTC)” (
Sep 23 16:43:50 raspberrypi satnogs-client[527]: 2017-09-23 16:43:50,741 - apscheduler.executors.default - INFO - Running job “post_data (trigger: interval[0:02:00], next run at: 2017-09-23 20:43:50 UTC)”
Sep 23 16:43:50 raspberrypi satnogs-client[527]: 2017-09-23 16:43:50,749 - apscheduler.executors.default - ERROR - Job “get_jobs (trigger: interval[0:01:00], next run at: 2017-09-23 20:44:50 UTC)” raised a
Sep 23 16:43:50 raspberrypi satnogs-client[527]: Traceback (most recent call last):
Sep 23 16:43:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/apscheduler/executors/base.py”, line 125, in run_job
Sep 23 16:43:50 raspberrypi satnogs-client[527]: retval = job.func(*job.args, **job.kwargs)
Sep 23 16:43:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/satnogsclient/scheduler/tasks.py”, line 154, in get_jobs
Sep 23 16:43:50 raspberrypi satnogs-client[527]: url, params=params, headers=headers, verify=settings.SATNOGS_VERIFY_SSL)
Sep 23 16:43:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/api.py”, line 72, in get
Sep 23 16:43:50 raspberrypi satnogs-client[527]: return request(‘get’, url, params=params, **kwargs)
Sep 23 16:43:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/api.py”, line 58, in request
Sep 23 16:43:50 raspberrypi satnogs-client[527]: return session.request(method=method, url=url, **kwargs)
Sep 23 16:43:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/sessions.py”, line 494, in request
Sep 23 16:43:50 raspberrypi satnogs-client[527]: prep = self.prepare_request(req)
Sep 23 16:43:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/sessions.py”, line 437, in prepare_request
Sep 23 16:43:50 raspberrypi satnogs-client[527]: hooks=merge_hooks(request.hooks, self.hooks),
Sep 23 16:43:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/models.py”, line 305, in prepare
Sep 23 16:43:50 raspberrypi satnogs-client[527]: self.prepare_url(url, params)
Sep 23 16:43:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/models.py”, line 379, in prepare_url
Sep 23 16:43:50 raspberrypi satnogs-client[527]: raise MissingSchema(error)
Sep 23 16:43:50 raspberrypi satnogs-client[527]: MissingSchema: Invalid URL ‘jobs/’: No schema supplied. Perhaps you meant http://jobs/?
Sep 23 16:43:50 raspberrypi satnogs-client[527]: 2017-09-23 16:43:50,754 - apscheduler.executors.default - INFO - Job “post_data (trigger: interval[0:02:00], next run at: 2017-09-23 20:45:50 UTC)” executed
Sep 23 16:44:50 raspberrypi satnogs-client[527]: 2017-09-23 16:44:50,703 - apscheduler.executors.default - INFO - Running job “get_jobs (trigger: interval[0:01:00], next run at: 2017-09-23 20:44:50 UTC)” (
Sep 23 16:44:50 raspberrypi satnogs-client[527]: 2017-09-23 16:44:50,729 - apscheduler.executors.default - ERROR - Job “get_jobs (trigger: interval[0:01:00], next run at: 2017-09-23 20:45:50 UTC)” raised a
Sep 23 16:44:50 raspberrypi satnogs-client[527]: Traceback (most recent call last):
Sep 23 16:44:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/apscheduler/executors/base.py”, line 125, in run_job
Sep 23 16:44:50 raspberrypi satnogs-client[527]: retval = job.func(*job.args, **job.kwargs)
Sep 23 16:44:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/satnogsclient/scheduler/tasks.py”, line 154, in get_jobs
Sep 23 16:44:50 raspberrypi satnogs-client[527]: url, params=params, headers=headers, verify=settings.SATNOGS_VERIFY_SSL)
Sep 23 16:44:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/api.py”, line 72, in get
Sep 23 16:44:50 raspberrypi satnogs-client[527]: return request(‘get’, url, params=params, **kwargs)
Sep 23 16:44:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/api.py”, line 58, in request
Sep 23 16:44:50 raspberrypi satnogs-client[527]: return session.request(method=method, url=url, **kwargs)
Sep 23 16:44:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/sessions.py”, line 494, in request
Sep 23 16:44:50 raspberrypi satnogs-client[527]: prep = self.prepare_request(req)
Sep 23 16:44:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/sessions.py”, line 437, in prepare_request
Sep 23 16:44:50 raspberrypi satnogs-client[527]: hooks=merge_hooks(request.hooks, self.hooks),
Sep 23 16:44:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/models.py”, line 305, in prepare
Sep 23 16:44:50 raspberrypi satnogs-client[527]: self.prepare_url(url, params)
Sep 23 16:44:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/models.py”, line 379, in prepare_url
Sep 23 16:44:50 raspberrypi satnogs-client[527]: raise MissingSchema(error)
Sep 23 16:44:50 raspberrypi satnogs-client[527]: MissingSchema: Invalid URL ‘jobs/’: No schema supplied. Perhaps you meant http://jobs/?
Sep 23 16:45:50 raspberrypi satnogs-client[527]: 2017-09-23 16:45:50,680 - apscheduler.executors.default - INFO - Running job “get_jobs (trigger: interval[0:01:00], next run at: 2017-09-23 20:45:50 UTC)” (
Sep 23 16:45:50 raspberrypi satnogs-client[527]: 2017-09-23 16:45:50,711 - apscheduler.executors.default - INFO - Running job “post_data (trigger: interval[0:02:00], next run at: 2017-09-23 20:47:50 UTC)”
Sep 23 16:45:50 raspberrypi satnogs-client[527]: 2017-09-23 16:45:50,719 - apscheduler.executors.default - ERROR - Job “get_jobs (trigger: interval[0:01:00], next run at: 2017-09-23 20:46:50 UTC)” raised a
Sep 23 16:45:50 raspberrypi satnogs-client[527]: Traceback (most recent call last):
Sep 23 16:45:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/apscheduler/executors/base.py”, line 125, in run_job
Sep 23 16:45:50 raspberrypi satnogs-client[527]: retval = job.func(*job.args, **job.kwargs)
Sep 23 16:45:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/satnogsclient/scheduler/tasks.py”, line 154, in get_jobs
Sep 23 16:45:50 raspberrypi satnogs-client[527]: url, params=params, headers=headers, verify=settings.SATNOGS_VERIFY_SSL)
Sep 23 16:45:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/api.py”, line 72, in get
Sep 23 16:45:50 raspberrypi satnogs-client[527]: return request(‘get’, url, params=params, **kwargs)
Sep 23 16:45:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/api.py”, line 58, in request
Sep 23 16:45:50 raspberrypi satnogs-client[527]: return session.request(method=method, url=url, **kwargs)
Sep 23 16:45:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/sessions.py”, line 494, in request
Sep 23 16:45:50 raspberrypi satnogs-client[527]: prep = self.prepare_request(req)
Sep 23 16:45:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/sessions.py”, line 437, in prepare_request
Sep 23 16:45:50 raspberrypi satnogs-client[527]: hooks=merge_hooks(request.hooks, self.hooks),
Sep 23 16:45:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/models.py”, line 305, in prepare
Sep 23 16:45:50 raspberrypi satnogs-client[527]: self.prepare_url(url, params)
Sep 23 16:45:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/models.py”, line 379, in prepare_url
Sep 23 16:45:50 raspberrypi satnogs-client[527]: raise MissingSchema(error)
Sep 23 16:45:50 raspberrypi satnogs-client[527]: MissingSchema: Invalid URL ‘jobs/’: No schema supplied. Perhaps you meant http://jobs/?
Sep 23 16:45:50 raspberrypi satnogs-client[527]: 2017-09-23 16:45:50,721 - apscheduler.executors.default - INFO - Job “post_data (trigger: interval[0:02:00], next run at: 2017-09-23 20:47:50 UTC)” executed
Sep 23 16:46:50 raspberrypi satnogs-client[527]: 2017-09-23 16:46:50,705 - apscheduler.executors.default - INFO - Running job “get_jobs (trigger: interval[0:01:00], next run at: 2017-09-23 20:46:50 UTC)” (
Sep 23 16:46:50 raspberrypi satnogs-client[527]: 2017-09-23 16:46:50,734 - apscheduler.executors.default - ERROR - Job “get_jobs (trigger: interval[0:01:00], next run at: 2017-09-23 20:47:50 UTC)” raised a
Sep 23 16:46:50 raspberrypi satnogs-client[527]: Traceback (most recent call last):
Sep 23 16:46:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/apscheduler/executors/base.py”, line 125, in run_job
Sep 23 16:46:50 raspberrypi satnogs-client[527]: retval = job.func(*job.args, **job.kwargs)
Sep 23 16:46:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/satnogsclient/scheduler/tasks.py”, line 154, in get_jobs
Sep 23 16:46:50 raspberrypi satnogs-client[527]: url, params=params, headers=headers, verify=settings.SATNOGS_VERIFY_SSL)
Sep 23 16:46:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/api.py”, line 72, in get
Sep 23 16:46:50 raspberrypi satnogs-client[527]: return request(‘get’, url, params=params, **kwargs)
Sep 23 16:46:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/api.py”, line 58, in request
Sep 23 16:46:50 raspberrypi satnogs-client[527]: return session.request(method=method, url=url, **kwargs)
Sep 23 16:46:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/sessions.py”, line 494, in request
Sep 23 16:46:50 raspberrypi satnogs-client[527]: prep = self.prepare_request(req)
Sep 23 16:46:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/sessions.py”, line 437, in prepare_request
Sep 23 16:46:50 raspberrypi satnogs-client[527]: hooks=merge_hooks(request.hooks, self.hooks),
Sep 23 16:46:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/models.py”, line 305, in prepare
Sep 23 16:46:50 raspberrypi satnogs-client[527]: self.prepare_url(url, params)
Sep 23 16:46:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/models.py”, line 379, in prepare_url
Sep 23 16:46:50 raspberrypi satnogs-client[527]: raise MissingSchema(error)
Sep 23 16:46:50 raspberrypi satnogs-client[527]: MissingSchema: Invalid URL ‘jobs/’: No schema supplied. Perhaps you meant http://jobs/?
Sep 23 16:47:50 raspberrypi satnogs-client[527]: 2017-09-23 16:47:50,679 - apscheduler.executors.default - INFO - Running job “get_jobs (trigger: interval[0:01:00], next run at: 2017-09-23 20:47:50 UTC)” (
Sep 23 16:47:50 raspberrypi satnogs-client[527]: 2017-09-23 16:47:50,703 - apscheduler.executors.default - INFO - Running job “post_data (trigger: interval[0:02:00], next run at: 2017-09-23 20:47:50 UTC)”
Sep 23 16:47:50 raspberrypi satnogs-client[527]: 2017-09-23 16:47:50,710 - apscheduler.executors.default - ERROR - Job “get_jobs (trigger: interval[0:01:00], next run at: 2017-09-23 20:48:50 UTC)” raised a
Sep 23 16:47:50 raspberrypi satnogs-client[527]: Traceback (most recent call last):
Sep 23 16:47:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/apscheduler/executors/base.py”, line 125, in run_job
Sep 23 16:47:50 raspberrypi satnogs-client[527]: retval = job.func(*job.args, **job.kwargs)
Sep 23 16:47:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/satnogsclient/scheduler/tasks.py”, line 154, in get_jobs
Sep 23 16:47:50 raspberrypi satnogs-client[527]: url, params=params, headers=headers, verify=settings.SATNOGS_VERIFY_SSL)
Sep 23 16:47:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/api.py”, line 72, in get
Sep 23 16:47:50 raspberrypi satnogs-client[527]: return request(‘get’, url, params=params, **kwargs)
Sep 23 16:47:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/api.py”, line 58, in request
Sep 23 16:47:50 raspberrypi satnogs-client[527]: return session.request(method=method, url=url, **kwargs)
Sep 23 16:47:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/sessions.py”, line 494, in request
Sep 23 16:47:50 raspberrypi satnogs-client[527]: prep = self.prepare_request(req)
Sep 23 16:47:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/sessions.py”, line 437, in prepare_request
Sep 23 16:47:50 raspberrypi satnogs-client[527]: hooks=merge_hooks(request.hooks, self.hooks),
Sep 23 16:47:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/models.py”, line 305, in prepare
Sep 23 16:47:50 raspberrypi satnogs-client[527]: self.prepare_url(url, params)
Sep 23 16:47:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/models.py”, line 379, in prepare_url
Sep 23 16:47:50 raspberrypi satnogs-client[527]: raise MissingSchema(error)
Sep 23 16:47:50 raspberrypi satnogs-client[527]: MissingSchema: Invalid URL ‘jobs/’: No schema supplied. Perhaps you meant http://jobs/?
Sep 23 16:47:50 raspberrypi satnogs-client[527]: 2017-09-23 16:47:50,716 - apscheduler.executors.default - INFO - Job “post_data (trigger: interval[0:02:00], next run at: 2017-09-23 20:49:50 UTC)” executed
Sep 23 16:48:50 raspberrypi satnogs-client[527]: 2017-09-23 16:48:50,705 - apscheduler.executors.default - INFO - Running job “get_jobs (trigger: interval[0:01:00], next run at: 2017-09-23 20:48:50 UTC)” (
Sep 23 16:48:50 raspberrypi satnogs-client[527]: 2017-09-23 16:48:50,734 - apscheduler.executors.default - ERROR - Job “get_jobs (trigger: interval[0:01:00], next run at: 2017-09-23 20:49:50 UTC)” raised a
Sep 23 16:48:50 raspberrypi satnogs-client[527]: Traceback (most recent call last):
Sep 23 16:48:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/apscheduler/executors/base.py”, line 125, in run_job
Sep 23 16:48:50 raspberrypi satnogs-client[527]: retval = job.func(*job.args, **job.kwargs)
Sep 23 16:48:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/satnogsclient/scheduler/tasks.py”, line 154, in get_jobs
Sep 23 16:48:50 raspberrypi satnogs-client[527]: url, params=params, headers=headers, verify=settings.SATNOGS_VERIFY_SSL)
Sep 23 16:48:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/api.py”, line 72, in get
Sep 23 16:48:50 raspberrypi satnogs-client[527]: return request(‘get’, url, params=params, **kwargs)
Sep 23 16:48:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/api.py”, line 58, in request
Sep 23 16:48:50 raspberrypi satnogs-client[527]: return session.request(method=method, url=url, **kwargs)
Sep 23 16:48:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/sessions.py”, line 494, in request
Sep 23 16:48:50 raspberrypi satnogs-client[527]: prep = self.prepare_request(req)
Sep 23 16:48:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/sessions.py”, line 437, in prepare_request
Sep 23 16:48:50 raspberrypi satnogs-client[527]: hooks=merge_hooks(request.hooks, self.hooks),
Sep 23 16:48:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/models.py”, line 305, in prepare
Sep 23 16:48:50 raspberrypi satnogs-client[527]: self.prepare_url(url, params)
Sep 23 16:48:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/models.py”, line 379, in prepare_url
Sep 23 16:48:50 raspberrypi satnogs-client[527]: raise MissingSchema(error)
Sep 23 16:48:50 raspberrypi satnogs-client[527]: MissingSchema: Invalid URL ‘jobs/’: No schema supplied. Perhaps you meant http://jobs/?
Sep 23 16:49:50 raspberrypi satnogs-client[527]: 2017-09-23 16:49:50,678 - apscheduler.executors.default - INFO - Running job “get_jobs (trigger: interval[0:01:00], next run at: 2017-09-23 20:49:50 UTC)” (
Sep 23 16:49:50 raspberrypi satnogs-client[527]: 2017-09-23 16:49:50,703 - apscheduler.executors.default - INFO - Running job “post_data (trigger: interval[0:02:00], next run at: 2017-09-23 20:49:50 UTC)”
Sep 23 16:49:50 raspberrypi satnogs-client[527]: 2017-09-23 16:49:50,708 - apscheduler.executors.default - ERROR - Job “get_jobs (trigger: interval[0:01:00], next run at: 2017-09-23 20:50:50 UTC)” raised a
Sep 23 16:49:50 raspberrypi satnogs-client[527]: Traceback (most recent call last):
Sep 23 16:49:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/apscheduler/executors/base.py”, line 125, in run_job
Sep 23 16:49:50 raspberrypi satnogs-client[527]: retval = job.func(*job.args, **job.kwargs)
Sep 23 16:49:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/satnogsclient/scheduler/tasks.py”, line 154, in get_jobs
Sep 23 16:49:50 raspberrypi satnogs-client[527]: url, params=params, headers=headers, verify=settings.SATNOGS_VERIFY_SSL)
Sep 23 16:49:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/api.py”, line 72, in get
Sep 23 16:49:50 raspberrypi satnogs-client[527]: return request(‘get’, url, params=params, **kwargs)
Sep 23 16:49:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/api.py”, line 58, in request
Sep 23 16:49:50 raspberrypi satnogs-client[527]: return session.request(method=method, url=url, **kwargs)
Sep 23 16:49:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/sessions.py”, line 494, in request
Sep 23 16:49:50 raspberrypi satnogs-client[527]: prep = self.prepare_request(req)
Sep 23 16:49:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/sessions.py”, line 437, in prepare_request
Sep 23 16:49:50 raspberrypi satnogs-client[527]: hooks=merge_hooks(request.hooks, self.hooks),
Sep 23 16:49:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/models.py”, line 305, in prepare
Sep 23 16:49:50 raspberrypi satnogs-client[527]: self.prepare_url(url, params)
Sep 23 16:49:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/models.py”, line 379, in prepare_url
Sep 23 16:49:50 raspberrypi satnogs-client[527]: raise MissingSchema(error)
Sep 23 16:49:50 raspberrypi satnogs-client[527]: MissingSchema: Invalid URL ‘jobs/’: No schema supplied. Perhaps you meant http://jobs/?
Sep 23 16:49:50 raspberrypi satnogs-client[527]: 2017-09-23 16:49:50,711 - apscheduler.executors.default - INFO - Job “post_data (trigger: interval[0:02:00], next run at: 2017-09-23 20:51:50 UTC)” executed
Sep 23 16:50:50 raspberrypi satnogs-client[527]: 2017-09-23 16:50:50,711 - apscheduler.executors.default - INFO - Running job “get_jobs (trigger: interval[0:01:00], next run at: 2017-09-23 20:50:50 UTC)” (
Sep 23 16:50:50 raspberrypi satnogs-client[527]: 2017-09-23 16:50:50,741 - apscheduler.executors.default - ERROR - Job “get_jobs (trigger: interval[0:01:00], next run at: 2017-09-23 20:51:50 UTC)” raised a
Sep 23 16:50:50 raspberrypi satnogs-client[527]: Traceback (most recent call last):
Sep 23 16:50:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/apscheduler/executors/base.py”, line 125, in run_job
Sep 23 16:50:50 raspberrypi satnogs-client[527]: retval = job.func(*job.args, **job.kwargs)
Sep 23 16:50:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/satnogsclient/scheduler/tasks.py”, line 154, in get_jobs
Sep 23 16:50:50 raspberrypi satnogs-client[527]: url, params=params, headers=headers, verify=settings.SATNOGS_VERIFY_SSL)
Sep 23 16:50:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/api.py”, line 72, in get
Sep 23 16:50:50 raspberrypi satnogs-client[527]: return request(‘get’, url, params=params, **kwargs)
Sep 23 16:50:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/api.py”, line 58, in request
Sep 23 16:50:50 raspberrypi satnogs-client[527]: return session.request(method=method, url=url, **kwargs)
Sep 23 16:50:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/sessions.py”, line 494, in request
Sep 23 16:50:50 raspberrypi satnogs-client[527]: prep = self.prepare_request(req)
Sep 23 16:50:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/sessions.py”, line 437, in prepare_request
Sep 23 16:50:50 raspberrypi satnogs-client[527]: hooks=merge_hooks(request.hooks, self.hooks),
Sep 23 16:50:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/models.py”, line 305, in prepare
Sep 23 16:50:50 raspberrypi satnogs-client[527]: self.prepare_url(url, params)
Sep 23 16:50:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/models.py”, line 379, in prepare_url
Sep 23 16:50:50 raspberrypi satnogs-client[527]: raise MissingSchema(error)
Sep 23 16:50:50 raspberrypi satnogs-client[527]: MissingSchema: Invalid URL ‘jobs/’: No schema supplied. Perhaps you meant http://jobs/?
Sep 23 16:51:50 raspberrypi satnogs-client[527]: 2017-09-23 16:51:50,676 - apscheduler.executors.default - INFO - Running job “get_jobs (trigger: interval[0:01:00], next run at: 2017-09-23 20:51:50 UTC)” (
Sep 23 16:51:50 raspberrypi satnogs-client[527]: 2017-09-23 16:51:50,690 - apscheduler.executors.default - INFO - Running job “post_data (trigger: interval[0:02:00], next run at: 2017-09-23 20:51:50 UTC)”
Sep 23 16:51:50 raspberrypi satnogs-client[527]: 2017-09-23 16:51:50,696 - apscheduler.executors.default - ERROR - Job “get_jobs (trigger: interval[0:01:00], next run at: 2017-09-23 20:52:50 UTC)” raised a
Sep 23 16:51:50 raspberrypi satnogs-client[527]: Traceback (most recent call last):
Sep 23 16:51:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/apscheduler/executors/base.py”, line 125, in run_job
Sep 23 16:51:50 raspberrypi satnogs-client[527]: retval = job.func(*job.args, **job.kwargs)
Sep 23 16:51:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/satnogsclient/scheduler/tasks.py”, line 154, in get_jobs
Sep 23 16:51:50 raspberrypi satnogs-client[527]: url, params=params, headers=headers, verify=settings.SATNOGS_VERIFY_SSL)
Sep 23 16:51:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/api.py”, line 72, in get
Sep 23 16:51:50 raspberrypi satnogs-client[527]: return request(‘get’, url, params=params, **kwargs)
Sep 23 16:51:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/api.py”, line 58, in request
Sep 23 16:51:50 raspberrypi satnogs-client[527]: return session.request(method=method, url=url, **kwargs)
Sep 23 16:51:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/sessions.py”, line 494, in request
Sep 23 16:51:50 raspberrypi satnogs-client[527]: prep = self.prepare_request(req)
Sep 23 16:51:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/sessions.py”, line 437, in prepare_request
Sep 23 16:51:50 raspberrypi satnogs-client[527]: hooks=merge_hooks(request.hooks, self.hooks),
Sep 23 16:51:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/models.py”, line 305, in prepare
Sep 23 16:51:50 raspberrypi satnogs-client[527]: self.prepare_url(url, params)
Sep 23 16:51:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/models.py”, line 379, in prepare_url
Sep 23 16:51:50 raspberrypi satnogs-client[527]: raise MissingSchema(error)
Sep 23 16:51:50 raspberrypi satnogs-client[527]: MissingSchema: Invalid URL ‘jobs/’: No schema supplied. Perhaps you meant http://jobs/?
Sep 23 16:51:50 raspberrypi satnogs-client[527]: 2017-09-23 16:51:50,700 - apscheduler.executors.default - INFO - Job “post_data (trigger: interval[0:02:00], next run at: 2017-09-23 20:53:50 UTC)” executed
Sep 23 16:52:50 raspberrypi satnogs-client[527]: 2017-09-23 16:52:50,675 - apscheduler.executors.default - INFO - Running job “get_jobs (trigger: interval[0:01:00], next run at: 2017-09-23 20:52:50 UTC)” (
Sep 23 16:52:50 raspberrypi satnogs-client[527]: 2017-09-23 16:52:50,702 - apscheduler.executors.default - ERROR - Job “get_jobs (trigger: interval[0:01:00], next run at: 2017-09-23 20:53:50 UTC)” raised a
Sep 23 16:52:50 raspberrypi satnogs-client[527]: Traceback (most recent call last):
Sep 23 16:52:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/apscheduler/executors/base.py”, line 125, in run_job
Sep 23 16:52:50 raspberrypi satnogs-client[527]: retval = job.func(*job.args, **job.kwargs)
Sep 23 16:52:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/satnogsclient/scheduler/tasks.py”, line 154, in get_jobs
Sep 23 16:52:50 raspberrypi satnogs-client[527]: url, params=params, headers=headers, verify=settings.SATNOGS_VERIFY_SSL)
Sep 23 16:52:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/api.py”, line 72, in get
Sep 23 16:52:50 raspberrypi satnogs-client[527]: return request(‘get’, url, params=params, **kwargs)
Sep 23 16:52:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/api.py”, line 58, in request
Sep 23 16:52:50 raspberrypi satnogs-client[527]: return session.request(method=method, url=url, **kwargs)
Sep 23 16:52:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/sessions.py”, line 494, in request
Sep 23 16:52:50 raspberrypi satnogs-client[527]: prep = self.prepare_request(req)
Sep 23 16:52:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/sessions.py”, line 437, in prepare_request
Sep 23 16:52:50 raspberrypi satnogs-client[527]: hooks=merge_hooks(request.hooks, self.hooks),
Sep 23 16:52:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/models.py”, line 305, in prepare
Sep 23 16:52:50 raspberrypi satnogs-client[527]: self.prepare_url(url, params)
Sep 23 16:52:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/models.py”, line 379, in prepare_url
Sep 23 16:52:50 raspberrypi satnogs-client[527]: raise MissingSchema(error)
Sep 23 16:52:50 raspberrypi satnogs-client[527]: MissingSchema: Invalid URL ‘jobs/’: No schema supplied. Perhaps you meant http://jobs/?
Sep 23 16:53:50 raspberrypi satnogs-client[527]: 2017-09-23 16:53:50,675 - apscheduler.executors.default - INFO - Running job “get_jobs (trigger: interval[0:01:00], next run at: 2017-09-23 20:53:50 UTC)” (
Sep 23 16:53:50 raspberrypi satnogs-client[527]: 2017-09-23 16:53:50,701 - apscheduler.executors.default - ERROR - Job “get_jobs (trigger: interval[0:01:00], next run at: 2017-09-23 20:54:50 UTC)” raised a
Sep 23 16:53:50 raspberrypi satnogs-client[527]: Traceback (most recent call last):
Sep 23 16:53:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/apscheduler/executors/base.py”, line 125, in run_job
Sep 23 16:53:50 raspberrypi satnogs-client[527]: retval = job.func(*job.args, **job.kwargs)
Sep 23 16:53:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/satnogsclient/scheduler/tasks.py”, line 154, in get_jobs
Sep 23 16:53:50 raspberrypi satnogs-client[527]: url, params=params, headers=headers, verify=settings.SATNOGS_VERIFY_SSL)
Sep 23 16:53:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/api.py”, line 72, in get
Sep 23 16:53:50 raspberrypi satnogs-client[527]: return request(‘get’, url, params=params, **kwargs)
Sep 23 16:53:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/api.py”, line 58, in request
Sep 23 16:53:50 raspberrypi satnogs-client[527]: return session.request(method=method, url=url, **kwargs)
Sep 23 16:53:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/sessions.py”, line 494, in request
Sep 23 16:53:50 raspberrypi satnogs-client[527]: prep = self.prepare_request(req)
Sep 23 16:53:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/sessions.py”, line 437, in prepare_request
Sep 23 16:53:50 raspberrypi satnogs-client[527]: hooks=merge_hooks(request.hooks, self.hooks),
Sep 23 16:53:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/models.py”, line 305, in prepare
Sep 23 16:53:50 raspberrypi satnogs-client[527]: self.prepare_url(url, params)
Sep 23 16:53:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/models.py”, line 379, in prepare_url
Sep 23 16:53:50 raspberrypi satnogs-client[527]: raise MissingSchema(error)
Sep 23 16:53:50 raspberrypi satnogs-client[527]: MissingSchema: Invalid URL ‘jobs/’: No schema supplied. Perhaps you meant http://jobs/?
Sep 23 16:53:50 raspberrypi satnogs-client[527]: 2017-09-23 16:53:50,704 - apscheduler.executors.default - INFO - Running job “post_data (trigger: interval[0:02:00], next run at: 2017-09-23 20:55:50 UTC)”
Sep 23 16:53:50 raspberrypi satnogs-client[527]: 2017-09-23 16:53:50,725 - apscheduler.executors.default - INFO - Job “post_data (trigger: interval[0:02:00], next run at: 2017-09-23 20:55:50 UTC)” executed
Sep 23 16:54:50 raspberrypi satnogs-client[527]: 2017-09-23 16:54:50,696 - apscheduler.executors.default - INFO - Running job “get_jobs (trigger: interval[0:01:00], next run at: 2017-09-23 20:54:50 UTC)” (
Sep 23 16:54:50 raspberrypi satnogs-client[527]: 2017-09-23 16:54:50,720 - apscheduler.executors.default - ERROR - Job “get_jobs (trigger: interval[0:01:00], next run at: 2017-09-23 20:55:50 UTC)” raised a
Sep 23 16:54:50 raspberrypi satnogs-client[527]: Traceback (most recent call last):
Sep 23 16:54:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/apscheduler/executors/base.py”, line 125, in run_job
Sep 23 16:54:50 raspberrypi satnogs-client[527]: retval = job.func(*job.args, **job.kwargs)
Sep 23 16:54:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/satnogsclient/scheduler/tasks.py”, line 154, in get_jobs
Sep 23 16:54:50 raspberrypi satnogs-client[527]: url, params=params, headers=headers, verify=settings.SATNOGS_VERIFY_SSL)
Sep 23 16:54:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/api.py”, line 72, in get
Sep 23 16:54:50 raspberrypi satnogs-client[527]: return request(‘get’, url, params=params, **kwargs)
Sep 23 16:54:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/api.py”, line 58, in request
Sep 23 16:54:50 raspberrypi satnogs-client[527]: return session.request(method=method, url=url, **kwargs)
Sep 23 16:54:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/sessions.py”, line 494, in request
Sep 23 16:54:50 raspberrypi satnogs-client[527]: prep = self.prepare_request(req)
Sep 23 16:54:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/sessions.py”, line 437, in prepare_request
Sep 23 16:54:50 raspberrypi satnogs-client[527]: hooks=merge_hooks(request.hooks, self.hooks),
Sep 23 16:54:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/models.py”, line 305, in prepare
Sep 23 16:54:50 raspberrypi satnogs-client[527]: self.prepare_url(url, params)
Sep 23 16:54:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/models.py”, line 379, in prepare_url
Sep 23 16:54:50 raspberrypi satnogs-client[527]: raise MissingSchema(error)
Sep 23 16:54:50 raspberrypi satnogs-client[527]: MissingSchema: Invalid URL ‘jobs/’: No schema supplied. Perhaps you meant http://jobs/?
Sep 23 16:55:50 raspberrypi satnogs-client[527]: 2017-09-23 16:55:50,672 - apscheduler.executors.default - INFO - Running job “get_jobs (trigger: interval[0:01:00], next run at: 2017-09-23 20:55:50 UTC)” (
Sep 23 16:55:50 raspberrypi satnogs-client[527]: 2017-09-23 16:55:50,687 - apscheduler.executors.default - ERROR - Job “get_jobs (trigger: interval[0:01:00], next run at: 2017-09-23 20:56:50 UTC)” raised a
Sep 23 16:55:50 raspberrypi satnogs-client[527]: Traceback (most recent call last):
Sep 23 16:55:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/apscheduler/executors/base.py”, line 125, in run_job
Sep 23 16:55:50 raspberrypi satnogs-client[527]: retval = job.func(*job.args, **job.kwargs)
Sep 23 16:55:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/satnogsclient/scheduler/tasks.py”, line 154, in get_jobs
Sep 23 16:55:50 raspberrypi satnogs-client[527]: url, params=params, headers=headers, verify=settings.SATNOGS_VERIFY_SSL)
Sep 23 16:55:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/api.py”, line 72, in get
Sep 23 16:55:50 raspberrypi satnogs-client[527]: return request(‘get’, url, params=params, **kwargs)
Sep 23 16:55:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/api.py”, line 58, in request
Sep 23 16:55:50 raspberrypi satnogs-client[527]: return session.request(method=method, url=url, **kwargs)
Sep 23 16:55:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/sessions.py”, line 494, in request
Sep 23 16:55:50 raspberrypi satnogs-client[527]: prep = self.prepare_request(req)
Sep 23 16:55:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/sessions.py”, line 437, in prepare_request
Sep 23 16:55:50 raspberrypi satnogs-client[527]: hooks=merge_hooks(request.hooks, self.hooks),
Sep 23 16:55:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/models.py”, line 305, in prepare
Sep 23 16:55:50 raspberrypi satnogs-client[527]: self.prepare_url(url, params)
Sep 23 16:55:50 raspberrypi satnogs-client[527]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/requests/models.py”, line 379, in prepare_url
Sep 23 16:55:50 raspberrypi satnogs-client[527]: raise MissingSchema(error)
Sep 23 16:55:50 raspberrypi satnogs-client[527]: MissingSchema: Invalid URL ‘jobs/’: No schema supplied. Perhaps you meant http://jobs/?
Sep 23 16:55:50 raspberrypi satnogs-client[527]: 2017-09-23 16:55:50,691 - apscheduler.executors.default - INFO - Running job “post_data (trigger: interval[0:02:00], next run at: 2017-09-23 20:57:50 UTC)”
Sep 23 16:55:50 raspberrypi satnogs-client[527]: 2017-09-23 16:55:50,698 - apscheduler.executors.default - INFO - Job “post_data (trigger: interval[0:02:00], next run at: 2017-09-23 20:57:50 UTC)” executed
lines 256-312/312 (END)
Hey there,
Looking quickly through the logs, your SATNOGS_NETWORK_API_URL seems to be wrong. Which one are you using?
Thanks for the response. It’s “network-dev.satnogs.org”.
I’ve got it connecting now. My initial setup was using the setup utility, but it seems to strip off the https:// and /api/. When I went back and entered it does not retain the setting. I manually edited etc/default/satnogs-client and was able to connect.
Aha! good catch! @Acinonyx any ideas on the striping ? ^
Thanks for the help! I’ll try to test a little today and see if I can get some better symptoms. However, it may be that the script isn’t updating changes. I may have entered that url to start with, but can’t recall.
As you’ve seen, I have two stations currently running (144 & 145). Both are online using the Pi image and were setup in the same fashion. It seems that satnogs-setup does not overwrite the url field once it’s populated.
However, this was an interesting observation from 144:
That field is missing from the config all together even though it was typed into the initial setup.
Anyhow, both of mine are up now but I thought the data may be helpful. Now to figure out the gain situation!
Thanks again!
@Acinonyx is the one that coded the setup script. He would know how to deal with the issue.
@nb3t Let us know when you figured out the gain settings, so we can start some scheduling on it for testing and then move the station to production Network! Welcome!
@Acinonyx let me know if you want or need me to test anything on this end.
@pierros Thanks! I hoping that I can get it dialed in a little better today. The VHF station is receiving but not decode quality. Looking at some other stations it looks like higher gain seems to be favored.
What is your setup? Antenna? LNA? Receiver?
At the moment, I have both stations on turnstile antennas with and LNA on both. The receivers are both rtl based, “NooElec NESDR SMArt - Premium RTL-SDR w/ Aluminum Enclosure, 0.5PPM TCXO, SMA Input. RTL2832U & R820T2”.
Nice! Which LNA do you use?
One is an LNAforall and one is the Amsat US preamp.
@pierros The UHF node (144) should be at a spot you can play with it and test. I’ve received a few good passes which are flagged, but will continue to dial in the gain.
https://network-dev.satnogs.org/observations/6308/
https://network-dev.satnogs.org/observations/6307/
https://network-dev.satnogs.org/observations/6302/
The VHF station (145) is up and behaving as well:
https://network-dev.satnogs.org/observations/6370/
I was also working this pass. This is pretty interesting, you can see my transmissions stacked with the ISS.
The forward slash stripping bug should be fixed now. You can re-run sudo satnogs-setup to update your SatNOGS client system.
Great, thank you for the update and response!
