Raspbian SatNOGS client image issues
I’ve noticed that not all files are being uploaded to SatNOGS. The /tmp/.satnogs/data/ gets rather full then the client no longer is seen at dev-network, however still shows as online.
For my station, last observation was around 1500z 22/09/2017.
/tmp/.satnogs/data/ contains 12 files - 280Mb
/tmp/.satnogs/data/complete - contains 13 files - 131Mb
pi@satnogs-vhf:~ $ df
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/root 14810864 2315324 11850136 17% /
devtmpfs 470176 0 470176 0% /dev
tmpfs 474784 0 474784 0% /dev/shm
tmpfs 474784 47876 426908 11% /run
tmpfs 5120 4 5116 1% /run/lock
tmpfs 474784 0 474784 0% /sys/fs/cgroup
tmpfs 474784 419552 55232 89% /tmp/.satnogs
/dev/mmcblk0p1 42152 21472 20681 51% /boot
tmpfs 94956 0 94956 0% /run/user/1000
Maybe tmpfs needs be adjusted for more space in /tmp/.satnogs/ and less in others?
A few questions:
Why do the files remain and not deleted after upload? (audio & waterfall)
Why are they not all uploaded and remain in /tmp/.satnogs/data/ (data & waterfall)
Is there a scheduled cleanup?
Interestingly, the system made using stretch and following the fedora instructions, does not use tmpfs for /tmp/.satnogs/, however it still has many files sitting in /tmp/.satnogs/data/complete/
It’s done it again :frowning:
tmpfs 474784 474784 0 100% /tmp/.satnogs
Think I’ll have to back to a different image.
It should have cleaned them up. @fredy any ideas?
Have you followed the step 1.11 at https://docs.satnogs.org/en/stable/satnogs-client/doc/raspi-install.html ?
Satnogs client itself doesn’t delete completed observations as some users may need them locally, so you need to create a new cron job for it.
Not sure why some uploads fail. In the past this happened due to bad internet connection, you need to check your logs for it. Do you run satnogs client manually or you use one of the automatic solutions(supervisord or systemd)?
EDIT: just realized that we are discussing for the rasbian image… probably the step above is not included. cc @Acinonyx who have worked on the image generation.
Yes, it was the Raspbian image. That step not included.
I believe the images uses systemd.
Some cleanup would be handy and increase /tmp/.satnogs. Did find that can fill rather quick. Some waterfall files have been >50Mb
Interesting how .ogg files virtually always get uploaded, not so for waterfall. The latter helps to adjust gain.
As a trial, I’ve gone back to a manual build, but upgraded to latest gr-satnogs and satnogs-client.
Thanks for your feedback! There is already a pending merge request to clean up after completed jobs.
There can also be leftover data from incomplete jobs. We could either clean this up in the client, via a cron job or leave it as a manual maintenance task.
Today I tried again with the latest raspbian build.
I get the following error. No files generated in data folder.
Sep 26 20:22:19 raspberrypi satnogs-client[528]: 2017-09-26 20:22:19,950 - satnogsclient - DEBUG - Received message: RPRT 0
Sep 26 20:22:20 raspberrypi satnogs-client[528]: 2017-09-26 20:22:20,064 - satnogsclient - DEBUG - Sending message: F 145983278
Exception in thread Thread-22:
Sep 26 20:21:31 raspberrypi satnogs-client[528]: Traceback (most recent call last):
Sep 26 20:21:31 raspberrypi satnogs-client[528]: File “/usr/lib/python2.7/threading.py”, line 801, in __bootstrap_inner
Sep 26 20:21:31 raspberrypi satnogs-client[528]: self.run()
Sep 26 20:21:31 raspberrypi satnogs-client[528]: File “/usr/lib/python2.7/threading.py”, line 754, in run
Sep 26 20:21:31 raspberrypi satnogs-client[528]: self.__target(*self.__args, **self.__kwargs)
Sep 26 20:21:31 raspberrypi satnogs-client[528]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/satnogsclient/observer/worker.py”, line 13
Sep 26 20:21:31 raspberrypi satnogs-client[528]: self.send_to_socket(p, sock)
Sep 26 20:21:31 raspberrypi satnogs-client[528]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/satnogsclient/observer/worker.py”, line 18
Sep 26 20:21:31 raspberrypi satnogs-client[528]: position = sock.send(“p\n”).split(’\n’)
Sep 26 20:21:31 raspberrypi satnogs-client[528]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/satnogsclient/observer/commsocket.py”, lin
Sep 26 20:21:31 raspberrypi satnogs-client[528]: self.s.send(message)
Sep 26 20:21:31 raspberrypi satnogs-client[528]: error: [Errno 32] Broken pipe
Any one seen this?
also here
Sep 26 21:33:02 raspberrypi satnogs-client[806]: 2017-09-26 21:33:02,994 - satnogsclient - DEBUG - Received message: RPRT 0
Sep 26 21:33:03 raspberrypi satnogs-client[806]: Exception in thread Thread-24:
Sep 26 21:33:03 raspberrypi satnogs-client[806]: Traceback (most recent call last):
Sep 26 21:33:03 raspberrypi satnogs-client[806]: File “/usr/lib/python2.7/threading.py”, line 801, in __bootstrap_inner
Sep 26 21:33:03 raspberrypi satnogs-client[806]: self.run()
Sep 26 21:33:03 raspberrypi satnogs-client[806]: File “/usr/lib/python2.7/threading.py”, line 754, in run
Sep 26 21:33:03 raspberrypi satnogs-client[806]: self.__target(*self.__args, **self.__kwargs)
Sep 26 21:33:03 raspberrypi satnogs-client[806]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/satnogsclient/observer/worker.py”, line 127, in _communicate_tracking_info
Sep 26 21:33:03 raspberrypi satnogs-client[806]: self.check_observation_end_reached()
Sep 26 21:33:03 raspberrypi satnogs-client[806]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/satnogsclient/observer/worker.py”, line 175, in check_observation_end_reached
Sep 26 21:33:03 raspberrypi satnogs-client[806]: self.trackstop()
Sep 26 21:33:03 raspberrypi satnogs-client[806]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/satnogsclient/observer/worker.py”, line 168, in trackstop
Sep 26 21:33:03 raspberrypi satnogs-client[806]: os.killpg(os.getpgid(self._gnu_proc.pid), signal.SIGKILL)
Sep 26 21:33:03 raspberrypi satnogs-client[806]: OSError: [Errno 3] No such process
It is possibly the same issue with the missing cleanup of completed jobs in the client. It could be that the system ran out of memory and started killing processes randomly. In the first case it may be rotctld and in the second GNU Radio.
This issue will be fixed with the release of SatNOGS client version 0.5 hopefully in a few days.
More Information regarding above logs: I have also tried building satnogs-client 0 branch locally, with similar results. Tried Fedora and Rasbian on raspberry pi 3. Regarding cleanup, the logs were on fresh system. I have tried this with multiple observations. I do-not have any rotor so did not set any related settings in the BASIC or ADVANCED settings page for them.
@Jferns, try the following:
HAMLIB_UTILS_ROT_ENABLED → Yes
HAMLIB_UTILS_ROT_OPTS → -m 1
This will enable the hamlib dummy rotator for the client.
I just tried on latest version of client, using False for the HAMLIB_UTILSROT_ENABLED (without a rotator) and it worked out just fine.
Figured out.
@Acinonyx @pierros, Can “no”, “No”, “False” be used interchangeably here?
I think it should be False. Did you find something else?
Well, I’ve gone and broken my systems :frowning:
Had client 0.4 running on my VHF system, reasonably well.
(jessie upgraded to stretch with gr-satnogs and satnogs-client manually installed)
Upgraded to 0.5 using:
sudo systemctl stop satnogs-client.service
sudo pip install satnogsclient --upgrade
sudo reboot
When I looked at the confg page on port 5000, I found SATNOGS_COMPLETE_OUTPUT_PATH was blank and no directory was created for /tmp/.satnogs/data/complete I edited the .env to set the paramater.
I’m not getting any files created in /tmp/.satnogs/data/ and sub-directories. Of course nothing being uploaded to dev-network either.
What would have caused the upgrade from 0.4 to 0.5 to cause this? Do I need to upgrade gr-satnogs as well?
Gone from working system to nothing, except the jobs are still being scheduled and I think still atempting to collect data.
Of course I did the UHF system as well, but 0.3 to 0.5. It broke as well.
*Mental note to self: Only do 1 at a time!!
Hey @Zathras! Sorry for your troubles :frowning:
Did you check the https://wiki.satnogs.org/Compatibility page?
About SATNOGS_COMPLETE_OUTPUT_PATH, it is changed on v0.5 to be blank as the new default behaviour is after successful uploading to delete files (ogg, waterfall and data) and not moving them into the complete directory.
Edit: The rest seems to be compatibility issues between client and gr-satnogs.
Thanks guys.
I’ve changed the SATNOGS_COMPLETE_OUTPUT_PATH to blank.
Never knew about the Compatiblity page. Ok, so I need the latest gr-satnogs.
Now, not being a linux guru, how do I make sure I download and install the correct version? How do I check what version I have installed currently?
I tried git clone https://github.com/satnogs/gr-satnogs.git and recompile, but still not getting any data. Where is the data stored while and after processing. Couldn’t find ogg or waterfall files anywhere?
Sample of the log just after a METEOR-M 2 pass:
Oct 04 10:15:20 satnogs-vhf bash[700]: 2017-10-04 10:15:20,846 - satnogsclient - DEBUG - Sending message: F 137897423
Oct 04 10:15:20 satnogs-vhf bash[700]: 2017-10-04 10:15:20,849 - satnogsclient - DEBUG - Received message: RPRT 0
Oct 04 10:15:20 satnogs-vhf bash[700]: 2017-10-04 10:15:20,973 - satnogsclient - DEBUG - Sending message: F 137897422
Oct 04 10:15:20 satnogs-vhf bash[700]: 2017-10-04 10:15:20,978 - satnogsclient - DEBUG - Received message: RPRT 0
Oct 04 10:15:21 satnogs-vhf bash[700]: Exception in thread Thread-101:
Oct 04 10:15:21 satnogs-vhf bash[700]: Traceback (most recent call last):
Oct 04 10:15:21 satnogs-vhf bash[700]: File “/usr/lib/python2.7/threading.py”, line 801, in __bootstrap_inner
Oct 04 10:15:21 satnogs-vhf bash[700]: self.run()
Oct 04 10:15:21 satnogs-vhf bash[700]: File “/usr/lib/python2.7/threading.py”, line 754, in run
Oct 04 10:15:21 satnogs-vhf bash[700]: self.__target(*self.__args, **self.__kwargs)
Oct 04 10:15:21 satnogs-vhf bash[700]: File “/usr/local/lib/python2.7/dist-packages/satnogsclient/observer/worker.py”, line 127, in _communicate_tracking_info
Oct 04 10:15:21 satnogs-vhf bash[700]: self.check_observation_end_reached()
Oct 04 10:15:21 satnogs-vhf bash[700]: File “/usr/local/lib/python2.7/dist-packages/satnogsclient/observer/worker.py”, line 175, in check_observation_end_reached
Oct 04 10:15:21 satnogs-vhf bash[700]: self.trackstop()
Oct 04 10:15:21 satnogs-vhf bash[700]: File “/usr/local/lib/python2.7/dist-packages/satnogsclient/observer/worker.py”, line 168, in trackstop
Oct 04 10:15:21 satnogs-vhf bash[700]: os.killpg(os.getpgid(self._gnu_proc.pid), signal.SIGKILL)
Oct 04 10:15:21 satnogs-vhf bash[700]: OSError: [Errno 3] No such process
Oct 04 10:15:33 satnogs-vhf bash[700]: 2017-10-04 10:15:33,989 - apscheduler.executors.default - INFO - Running job “get_jobs (trigger: interval[0:01:00], next run at: 2017-10-04 02:16:33 UTC)” (scheduled at 2017-10-04 02:15:33.964267+00:00)
Oct 04 10:15:36 satnogs-vhf bash[700]: 2017-10-04 10:15:36,019 - satnogsclient - DEBUG - Opening TCP socket: 127.0.0.1:5011
Hi @Zathras – I’m new to SatNOGS, but since you mentioned having the Raspbian image up above:
  • You can check which version of gr-satnogs is present by running dpkg -l gr-satnogs:
pi@raspberrypi:~/.ssh $ dpkg -l gr-satnogs
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name                                  Version                 Architecture            Description
ii  gr-satnogs                            20171001.ae1e331-1      armhf                   SatNOGS GNU Radio Out-Of-Tree Module
Here, you can see that my version is “20171001.ae1e331-1” – meaning it was built October 1 2017, and it’s about a week old (looking for “ae1e331” on that page, you can see I’m a couple of updates behind.)
@Acinonyx, have I got those last two points right? Is there an intended way to fetch/apply the latest versions of packages (perhaps just sudo satnogs-setup without the -n argument)?
Hi saintaardvark,
Nope, that did not work for me. I’m not using the SatNOGS Raspbian image, just what created myself. The instructions no longer exist though :frowning: Which is a pity because I did refer to them all the time.
I had several issues with the SatNOGS Raspbian image, which is why I went back to my version.
This should not have happened. @fredy @comzeradd @Acinonyx did that happen on the Docathon move? Can we restore them somehow on the wiki?
