Is it possible to use raspberry pi zero (or zero W)? It would be a cheap setup. I tried using ansible raspbian
images and failed. I tried compiling gr-satnogs/satnogs-client which also failed on this setup.
Hey @Jferns ! I highly doubt that Pi Zero (or W) would be able to handle the gr-satnogs scripts. Would worth a try though!
How far did you get? Where did you fail?
Update: the new Pi Zero 2W seems up to the task running a SatNOGS station: Raspberry Pi Zero 2W
