Question about api/telemetry
Dear All
I wrote a software to retreive telemetry from satnogs database. The folowing URL is used : https://db.satnogs.org/api/telemetry?format=json&satellite=46287
I receive a set of 25 telemetry data in json format. An extract is given here :
[{“schema”:"",“app_source”:“sids”,“observer”:“HS4QLM-OK16rx”,“decoded”:"",“norad_cat_id”:46287,“transmitter”:"",“frame”:“82a088a6a8686ca4a6626ea6406cae92888a624062ae92888a64406303f03d494d435f54494d454f55543b353b3832”,“timestamp”:“2563-11-07T14:55:40Z”},{“schema”:"",“app_source”:“sids”,“observer”:“HS4QLM-OK16rx”,“decoded”:"",“norad_cat_id”:46287,“transmitter”:"",“frame”:“82a088a6a8686ca4a6626ea6406cae92888a624062ae92888a64406303f03d494d435f54494d454f55543b353b3832”,“timestamp”:“2563-11-07T14:55:40Z”}…]
The timestamp value seem not coherent : 2563-11-07T14:55:40Z for me it should be : 2020-11-07T14:55:40Z
Why the year value is 2563 ?
thanks for your help
Hey @XtopheSwl,
Thanks for pointing this out. I have contacted the observer to fix the date for the next frames that will be sent.
At first I thought this was probably a typo or something misconfigured, but discussing this in #satnogs chat channel, @YT2CQ told me that Thai calendar follows the Buddhist Era which is now at the year “2563”.
After I get confirmation from the observer that the issue is fixed I’m going to fix all the timestamps with this issue.
The issue is should be now fixed.
Dear
Thanks a lot. I have tested and it’s OK
I have an other question : How can we retreive telemetry data between two date ?
73’s
Christophe
You can use the start/end filters for example bellow you get all the ISS (25544) frames from 2021-01-01T00:00:00Z to 2021-01-13T00:00:00Z:
https://db.satnogs.org/api/telemetry/?satellite=25544&start=2021-01-01T00%3A00%3A00Z&end=2021-01-13T00%3A00%3A00Z
PS There is some active work on documentation these days which will make much easier to find your way through the API. Until then feel free to ask here. :slight_smile:
