Is it possible to set a proxy-server and port in the satnog software on the raspberry pi?
It is not supported out of the box in satnogs-setup. You will have to set the proxy env vars http_proxy and https_proxy in various places:
- APT configuration
- SatNOGS Client service configuration file (`/etc/default/satnogs-client’)
- SatNOGS Setup
APT config - you mean access-point right ? So many abbreviations with different meanings
Thanks for the answer - will try to setup the proxy
APT stands for Advanced Package Tool.
I’ve opened an issue about system-wide proxy settings support.
BTW, keep in mind that a firewall may prevent system clock synchronization. Raspberry Pis do not have an RTC backup battery and rely on NTP to set the time which cannot be served through a proxy. Correct time is very important for SatNOGS scheduled observations.
P.S. There is an open issue to sync clock using htpdate in cases a firewall prevents NTP use.
