I’m trying to get an AirSpy Mini working with SatNOGS, however I can’t seem to get the correct syntax in the config.
SoapySDRUtil --probe
######################################################Soapy SDR – the SDR abstraction library
Probe device
[INFO] [UHD] linux; GNU C++ version 8.3.0; Boost_106700; UHD_3.15.0.0-3satnogs1RtApiAlsa::getDeviceInfo: snd_pcm_open error for device (default), No such file or directory.
– Device identification
driver=Airspy
hardware=Airspy
device_id=0
origin=GitHub - pothosware/SoapyAirspy: Soapy SDR plugin for the Airspy
– Peripheral summary
Channels: 1 Rx, 0 Tx
Timestamps: NO
Other Settings:
* Bias tee - Enable the 4.5v DC Bias tee to power SpyVerter / LNA / etc. via antenna connection.
[key=biastee, default=false, type=bool]
* Bit Pack - Enable packing 4 12-bit samples into 3 16-bit words for 25% less USB trafic.
[key=bitpack, default=false, type=bool]
– RX Channel 0
Full-duplex: YES
Supports AGC: YES
Stream formats: CS16, CF32
Native format: CS16 [full-scale=32767]
Antennas: RX
Full gain range: [0, 45] dB
LNA gain range: [0, 15] dB
MIX gain range: [0, 15] dB
VGA gain range: [0, 15] dB
Full freq range: [24, 1800] MHz
RF freq range: [24, 1800] MHz
Sample rates: 6, 3 MSps
sudo -u satnogs SoapySDRUtil --args=“driver=airspy” --direction=RX --rate=3e6
[INFO] Using format CS16.
Stream format: CS16
Num channels: 1
Element size: 4 bytes
Begin RX rate test at 3 Msps
Starting stream loop, press Ctrl+C to exit… 2.99166 Msps 11.9666 MBps
However running this doesn’t work
susatnogs_fm.py
File “/usr/bin/satnogs_fm.py”, line 441, in
main()
File “/usr/bin/satnogs_fm.py”, line 424, in main
tb = top_block_cls(antenna=options.antenna, bb_freq=options.bb_freq, bw=options.bw, dc_removal=options.dc_removal, decoded_data_file_path=options.decoded_data_file_path, dev_args=options.dev_args, deviation=options.deviation, doppler_correction_per_sec=options.doppler_correction_per_sec, enable_iq_dump=options.enable_iq_dump, file_path=options.file_path, gain=options.gain, gain_mode=options.gain_mode, iq_file_path=options.iq_file_path, lo_offset=options.lo_offset, max_modulation_freq=options.max_modulation_freq, other_settings=options.other_settings, ppm=options.ppm, rigctl_port=options.rigctl_port, rx_freq=options.rx_freq, samp_rate_rx=options.samp_rate_rx, soapy_rx_device=options.soapy_rx_device, stream_args=options.stream_args, tune_args=options.tune_args, udp_IP=options.udp_IP, udp_port=options.udp_port, waterfall_file_path=options.waterfall_file_path)
File “/usr/bin/satnogs_fm.py”, line 89, in init
tune_args, settings, samp_rate_rx, “fc32”)
File “/usr/lib/python3/dist-packages/soapy/soapy_swig.py”, line 166, in make
return _soapy_swig.source_make(nchan, device, dev_args, stream_args, tune_args, other_settings, sampling_rate, type)
RuntimeError: SoapySDR::Device::make() no match
Current config (already tried resetting the config)
SatNOGS client configuration
satnogs_antenna: RX
satnogs_api_token: blahblahblah
satnogs_rx_samp_rate: 3e6
satnogs_soapy_rx_device: driver=airspy
satnogs_station_elev: ‘high’
satnogs_station_id: ‘-1’
satnogs_station_lat: ‘over here’
satnogs_station_lon: ‘lolz’
