I have several facilities retries and I always get this error …
Problems to configured groundstation
eb1ao
#1
KD9KCK
#2
You need to configure you ground stations ID in the satnogs-setup config
https://wiki.satnogs.org/SatNOGS_Client_Ansible#SatNOGS_Client_Setup
KD9KCK
#4
Did you click apply in the main part of the menu?
As that error says right in it. That its because the station id is not set.
KD9KCK
#7
I have no idea but if its not saving your not doing something correct.
Tell me exactly how you are entering this information.
(Also I am not part of the actually main team I am just a fellow station owner)
eb1ao
#10
I have already solved the problem … thanks to Ruben EA5BZ … I had the error of putting in my ID the name and not the station number … thanks for everything
