Hi There,
I am having problems opening the satnogs controller schematic file.
Trying both EAGLE and DesignSpark i get the following error:
“Error: line 1, column 1: Start tag expected.”
I am trying to generate a Gerber file to send off to Seeed to get the board and components assembled.
Any help would be much appreciated.
Thanks
Sam
Same problem trying to open the Rotary Encoder schematic file.
Thanks
@samhltn it is a KiCad project.
Thanks for that.
It seems the .cmp ( parts-to-module assignments) file is not supported by KiCad anymore… What would be the best approach to take to export a gerber file containing the PCB board and component assembly?
Thanks,
Sam
Which version our you checking out? The project has been converted to KiCad 5 format on v2.2.
