Since updating to latest satnogs client I have not had any successful observations - no waterfalls received. Config is r-pi 3B with genuine RTL-SDR. I think I followed all the set-up carefully. I get the support report below - any suggestions appreciated:
“versions”: {
“satnogs-client”: “1.3.1”,
“satnogs-client-ansible”: “202004031132”,
“gr-satnogs”: “2.1.2-1”,
“gr-soapy”: “2.1.2-1”,
“gnuradio”: “3.8.0.0-6”,
“satnogs-config”: “0.10.1”
“state”: {
“is-applied”: true,
“pending-tags”: null
“system”: {
“distribution”: {
“RELEASE”: “10”,
“CODENAME”: “buster”,
“ID”: “Raspbian”
“pending-updates”: true,
“platform”: {
“system”: “Linux”,
“node”: “satgroundstation”,
“release”: “4.19.97-v7+”,
“machine”: “armv7l”,
“processor”: “”
“memory”: {
“total”: 971055104,
“available”: 804249600,
“percent”: 17.2,
“used”: 104890368,
“free”: 593743872,
“active”: 124559360,
“inactive”: 190263296,
“buffers”: 18329600,
“cached”: 254091264,
“shared”: 6500352,
“slab”: 42979328
“disk”: {
“total”: 30293102592,
“used”: 3229790208,
“free”: 25785257984,
“percent”: 11.1
“configuration”: {
“satnogs_antenna”: “RX”,
“satnogs_rf_gain”: “38.2”,
“satnogs_station_elev”: “71”,
“satnogs_station_id”: “763”,
“satnogs_station_lat”: “51.6”,
“satnogs_station_lon”: “-1.291”
OK - so I see the problem maybe with the issue of gnuradio … needs updating.
Yep - that was it. 3.8.1 solves the problem. I’ll leave it here in case anybody else has same problem.
Hello Rob, witch command are you giving into thr RPi to get this repport about your status from the RPi?
Johan.
