Hello SA2KNG,
thanks a lot.
I did not know where to put the SATNOGS_ROT_MODEL/ SATNOGS_ROT_PORT variable. So I tried the echo "+p" | nc -w 1 localhost 4533
without them. It works. I can control the rotator.
The --set-conf=min_az=0,max_az=360,min_el=0,max_el=180
did unfortunately not change anything.
However, I am very sorry, I was sloppy, in contrast to what I said above, there is an error message in a satnogs-service journal file:
" Failed to establish a new connection: [Errno -3] Temporary failure in name resolution’))" (complete journal content below).
So, some TCP problem is present.
The satnogs webinterface can see my groundstation 3533 and the satnogs-monitor is synced to the webinterface too.
I am able to ping network.satnogs.org and a
“nc -zv network.satnogs.org 443”
gives
“Connection to network.satnogs.org 443 port [tcp/https] succeeded!”
Do you have any hunch where I could look further?
Any idea is extremely welcome.
Jan
---------------------------------- BEGIN ---------------------------------------
– Reboot –
Apr 17 10:45:14 ubadmin-PowerEdge-R210 systemd[1]: Started SatNOGS client.
Apr 17 10:45:37 ubadmin-PowerEdge-R210 satnogs-client[518]: satnogsclient.scheduler.tasks - ERROR - An error occurred trying to GET observation jobs from network
Apr 17 10:45:37 ubadmin-PowerEdge-R210 satnogs-client[518]: Traceback (most recent call last):
Apr 17 10:45:37 ubadmin-PowerEdge-R210 satnogs-client[518]: File “/usr/lib/python3/dist-packages/urllib3/connection.py”, line 159, in _new_conn
Apr 17 10:45:37 ubadmin-PowerEdge-R210 satnogs-client[518]: conn = connection.create_connection(
Apr 17 10:45:37 ubadmin-PowerEdge-R210 satnogs-client[518]: File “/usr/lib/python3/dist-packages/urllib3/util/connection.py”, line 61, in create_connection
Apr 17 10:45:37 ubadmin-PowerEdge-R210 satnogs-client[518]: for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
Apr 17 10:45:37 ubadmin-PowerEdge-R210 satnogs-client[518]: File “/usr/lib/python3.8/socket.py”, line 918, in getaddrinfo
Apr 17 10:45:37 ubadmin-PowerEdge-R210 satnogs-client[518]: for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
Apr 17 10:45:37 ubadmin-PowerEdge-R210 satnogs-client[518]: socket.gaierror: [Errno -3] Temporary failure in name resolution
Apr 17 10:45:37 ubadmin-PowerEdge-R210 satnogs-client[518]: During handling of the above exception, another exception occurred:
Apr 17 10:45:37 ubadmin-PowerEdge-R210 satnogs-client[518]: File “/usr/lib/python3/dist-packages/urllib3/connectionpool.py”, line 666, in urlopen
Apr 17 10:45:37 ubadmin-PowerEdge-R210 satnogs-client[518]: httplib_response = self._make_request(
Apr 17 10:45:37 ubadmin-PowerEdge-R210 satnogs-client[518]: File “/usr/lib/python3/dist-packages/urllib3/connectionpool.py”, line 377, in _make_request
Apr 17 10:45:37 ubadmin-PowerEdge-R210 satnogs-client[518]: self._validate_conn(conn)
Apr 17 10:45:37 ubadmin-PowerEdge-R210 satnogs-client[518]: File “/usr/lib/python3/dist-packages/urllib3/connectionpool.py”, line 1001, in _validate_conn
Apr 17 10:45:37 ubadmin-PowerEdge-R210 satnogs-client[518]: conn.connect()
Apr 17 10:45:37 ubadmin-PowerEdge-R210 satnogs-client[518]: File “/usr/lib/python3/dist-packages/urllib3/connection.py”, line 314, in connect
Apr 17 10:45:37 ubadmin-PowerEdge-R210 satnogs-client[518]: conn = self._new_conn()
Apr 17 10:45:37 ubadmin-PowerEdge-R210 satnogs-client[518]: File “/usr/lib/python3/dist-packages/urllib3/connection.py”, line 171, in _new_conn
Apr 17 10:45:37 ubadmin-PowerEdge-R210 satnogs-client[518]: raise NewConnectionError(
Apr 17 10:45:37 ubadmin-PowerEdge-R210 satnogs-client[518]: urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x7f6fe2274b50>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution
Apr 17 10:45:37 ubadmin-PowerEdge-R210 satnogs-client[518]: File “/var/lib/satnogs/lib/python3.8/site-packages/requests/adapters.py”, line 489, in send
Apr 17 10:45:37 ubadmin-PowerEdge-R210 satnogs-client[518]: resp = conn.urlopen(
Apr 17 10:45:37 ubadmin-PowerEdge-R210 satnogs-client[518]: File “/usr/lib/python3/dist-packages/urllib3/connectionpool.py”, line 720, in urlopen
Apr 17 10:45:37 ubadmin-PowerEdge-R210 satnogs-client[518]: retries = retries.increment(
Apr 17 10:45:37 ubadmin-PowerEdge-R210 satnogs-client[518]: File “/usr/lib/python3/dist-packages/urllib3/util/retry.py”, line 436, in increment
Apr 17 10:45:37 ubadmin-PowerEdge-R210 satnogs-client[518]: raise MaxRetryError(_pool, url, error or ResponseError(cause))
Apr 17 10:45:37 ubadmin-PowerEdge-R210 satnogs-client[518]: urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host=‘network.satnogs.org’, port=443): Max retries exceeded with url: /api/jobs/?ground_station=3533&lat=49.626&lon=6.159&alt=350 (Caused by NewConnectionError(‘<urllib3.connection.VerifiedHTTPSConnection object at 0x7f6fe2274b50>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution’))
Apr 17 10:45:37 ubadmin-PowerEdge-R210 satnogs-client[518]: File “/var/lib/satnogs/lib/python3.8/site-packages/satnogsclient/scheduler/tasks.py”, line 191, in get_jobs
Apr 17 10:45:37 ubadmin-PowerEdge-R210 satnogs-client[518]: response = requests.get(url,
Apr 17 10:45:37 ubadmin-PowerEdge-R210 satnogs-client[518]: File “/var/lib/satnogs/lib/python3.8/site-packages/requests/api.py”, line 73, in get
Apr 17 10:45:37 ubadmin-PowerEdge-R210 satnogs-client[518]: return request(“get”, url, params=params, **kwargs)
Apr 17 10:45:37 ubadmin-PowerEdge-R210 satnogs-client[518]: File “/var/lib/satnogs/lib/python3.8/site-packages/requests/api.py”, line 59, in request
Apr 17 10:45:37 ubadmin-PowerEdge-R210 satnogs-client[518]: return session.request(method=method, url=url, **kwargs)
Apr 17 10:45:37 ubadmin-PowerEdge-R210 satnogs-client[518]: File “/var/lib/satnogs/lib/python3.8/site-packages/requests/sessions.py”, line 587, in request
Apr 17 10:45:37 ubadmin-PowerEdge-R210 satnogs-client[518]: resp = self.send(prep, **send_kwargs)
Apr 17 10:45:37 ubadmin-PowerEdge-R210 satnogs-client[518]: File “/var/lib/satnogs/lib/python3.8/site-packages/requests/sessions.py”, line 701, in send
Apr 17 10:45:37 ubadmin-PowerEdge-R210 satnogs-client[518]: r = adapter.send(request, **kwargs)
Apr 17 10:45:37 ubadmin-PowerEdge-R210 satnogs-client[518]: File “/var/lib/satnogs/lib/python3.8/site-packages/requests/adapters.py”, line 565, in send
Apr 17 10:45:37 ubadmin-PowerEdge-R210 satnogs-client[518]: raise ConnectionError(e, request=request)
Apr 17 10:45:37 ubadmin-PowerEdge-R210 satnogs-client[518]: requests.exceptions.ConnectionError: HTTPSConnectionPool(host=‘network.satnogs.org’, port=443): Max retries exceeded with url: /api/jobs/?ground_station=3533&lat=49.626&lon=6.159&alt=350 (Caused by NewConnectionError(‘<urllib3.connection.VerifiedHTTPSConnection object at 0x7f6fe2274b50>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution’))
Apr 17 10:55:11 ubadmin-PowerEdge-R210 satnogs-client[518]: rot_init called
Apr 17 10:55:11 ubadmin-PowerEdge-R210 satnogs-client[518]: dummy: _init called
Apr 17 10:55:11 ubadmin-PowerEdge-R210 satnogs-client[518]: rot_register (1)
Apr 17 10:55:11 ubadmin-PowerEdge-R210 satnogs-client[518]: rot_register (2)
Apr 17 10:55:11 ubadmin-PowerEdge-R210 satnogs-client[518]: dummy_rot_init called
Apr 17 10:55:11 ubadmin-PowerEdge-R210 satnogs-client[518]: rot_open called
Apr 17 10:55:11 ubadmin-PowerEdge-R210 satnogs-client[518]: dummy_rot_open called
Apr 17 10:55:11 ubadmin-PowerEdge-R210 satnogs-client[518]: rot_get_position called
Apr 17 10:55:11 ubadmin-PowerEdge-R210 satnogs-client[518]: dummy_rot_get_position called
Apr 17 10:55:11 ubadmin-PowerEdge-R210 satnogs-client[518]: rot_set_position called
Apr 17 10:55:16 ubadmin-PowerEdge-R210 satnogs-client[1651]: [INFO] Opening HackRF One #0 f77c60dc255784c3…
Apr 17 11:07:04 ubadmin-PowerEdge-R210 satnogs-client[1733]: [INFO] Opening HackRF One #0 f77c60dc255784c3…
----------------------------------- END --------------------------------------
