Hello all,
I have a problem with my rtlsdr key (R2832U and R820T) The rtl_test is not correct (see screenshot). I have the same problem with another key of the same type. When I do a second test the key is no longer recognized.
I turn around…
Thanks for your help
pi@raspberrypi:~ $ rtl_test
Found 1 device(s):
0: , , SN:
rtlsdr_write_reg failed with -1
Resetting device…
rtlsdr_write_reg failed with -4
Info: This tool will continuously read from the device, and report if
samples get lost. If you observe no further output, everything is fine.
Reading samples in async mode…
Failed to submit transfer 0!
Library error -5, exiting…
