While trying to add a ground station, the form at https://network-dev.satnogs.org/users/fjkraan/ always responds with an error. Filling in each field still results in “Some fields missing on the form”. The Antenna field is read-only for some reason. I tried this with several browsers on Linux and even Edge on Windows 10.
The client software installed ok on the Raspberry Pi 2B, and works up to the point where it wants the ground station.
Thanks for the reply. Attached is an image just before I press Submit and get the error message. I did select an antenna (without really having one yet). The frequency is still 0.000 MHz and I do not see a way to change that. I also tried adding an Image; same result.
No, sorry, I did not find a solution. I tried with several browsers and operating systems, and consider it a server side issue. But it is good to know I am not the only one having the problem :-).
Just now I succeeded in creating a groundstation on dev with a VHF antenna (otherwise the same data as above), but cannot reproduce it :-(. The frequency was ok in the overview.
This problem is when the altitude has a decimal value.
It happens when you try to edit the station as well with a non-integer altitude value. I think the following diagram from the overview shows where the potential error might be. Adding input validation and feedback might be a good step in resolving this issue properly.
