Hello all,
I’m looking into setting up a PoE-powered, no-rotator, ground station about 50ft from my residence. Current thinking is to keep short runs of coax between Pi/RTL-SDR and the Antenna ({something} fairly omni, but circular-polarized), with a bias-T-powered LNA figuring in somewhere on one end of the coax or another.
I’m still working through ideas on protecting the residential, plenum-rated Cat5e cable from the elements (UV, moisture, etc…) and may eventually go with a metal or PVC conduit burial solution, but for right now I may simply use one of those 50’ flexible (woven sheath w/ rubber core) garden hoses to keep things protected, and temporary (as I sort things out). The weight of the protection will keep the Cat5 from coiling up into a tripping hazard, and should protect it a bit more from careless footwork.
I want to keep the design somewhat flexible and portable because I plan on having a “mobile-demo” version to take to high-schools and other local sci/tech/geek/STEM gatherings to promote the learning opportunities for building your own system. So I like the idea of a semi-protected Cat5e cable that I can string out on a parking lot, or school campus that’ll weather the wear & tear, but also illustrate that cheap solutions (garden hose) work just fine if you think it through.
The PoE injector will stay sheltered, and 50’ of Cat5e is “nothing” when it comes to delivering enough juice to power a Pi + LNA, etc… so I’m less worried about power delivery than protecting the items at either end. While I can more easily write off the loss of a Pi, loosing the PoE network switch would hurt.
50’ of {anything} will also act like a great big antenna though, so I’m imagining that some ferrite bead protection, or toroid choke(s) are going to be necessary.
Also, having done some cursory research on the interwebs, with folks running Ethernet out to she-sheds, and other IoT devices, lots of folks speak of having had their network gear blown out by the EMI surge from nearby lightning strikes. I’m not even talking about direct hits… just induced EMI coupled to the long run of Cat5, producing a surge that runs out to either end of the cable.
Amazon (and other sources) list quite a few different brands and solutions, but I’m curious what others have done to protect their PoE devices when they run the Cat5e outside.
(obviously depending on where you live, brands and availability will vary, but just looking to get a “feel” for how in-depth others have thought this through.)
I welcome any suggestions or recommendations.
Cheers,
-Lucky
