Hi, since Jan 23 my 2m station 2925 was working very well. Now 2 days ago no more decoding!
I did check rf side to Pluto >> OK
I did check Pluto to ethernet >> OK (Pluto is conneted to Raspberry via eth.
I did check Raspberry to eth >> OK
I did check with “probe” connection to Pluto >> Fault (see picture)
I did write a image (the state where all was working well) to a new SD card and start Pi with it
I am getting the same error message
Any idea about this?
Thank you for support!
Armin
HB9MFL
thank you for feedback.
I could not load the app sdrpp on the Pi.
With another app connected to windows the Pluto works well.
I can ping the Pluto via ETH from the Pi.
My understanding: With satnogs-setup I set all paramters for the Pluto
When an obeservation is active theses parameters are loaded to the Pluto
73
Armin
https://wiki.satnogs.org/SatNOGS_Monitor#Installation
After all was updated and upgraded I got the same segmentation fault using --probe
Starting the Satnogs-monitor he was also not working as expected. Did not show future passes as sheduled. See picture:
step 1 and 2 looks good.
Why step 3 and not lsf packaged deb ?
step 4, does not work properly since the api pagination change.
Only step 3 would cause issues with soapy probe, not sure what you ran, but probe needs to have the address specified like SoapySDRUtil --probe="driver=plutosdr,hostname=192.168.2.1" or what your setup has.
The output from SoapySDRUtil --info is also pretty useful to see how the drivers look.
No pluto found but NO segmentaion fault. (Pluto driver not installed yet)
Then I did check explizit for the pluto which is On and on the net reacheable with ping and got this:
SatNOGS Client Setup - SatNOGS Wiki
The client setup for Pluto SDR.
Checks with --info --find --probe --probe =“driver=plutosdr,hostname=192.168.1.119”
I got answers which make sense as the driver for Pluto is not yet installed.
But no fault at that time
apt search plutosdr
The response from system was not exact the same as on yours.
But no fault at that time.
sudo apt install soapysdr-module-plutosdr
Went thru with no errors shown.
Reboot the system
Now again these checks with --info --find --probe --probe =“driver=plutosdr,hostname=192.168.1.119”
With --find and --probe and --probe="driver…
I got no answer but the message segmenation fault.
This is exaclty the same situation which I had with the systen which was running 1 1/2 year successful and from one day to another did no more work.
Also on this system I got the same message segmentaion fault when I did the checks.
I did test with another PI same result.
I did test the Pluto with other software is OK.
Although I am not running the latest 0.38 firmware on my pluto.
Maybe try updating to 0.37 or 0.38 ?
I am running this under docker, but that should not make much of a difference.
If you don’t know what version you are running, ssh into it and it is in the welcome message:
Hi Daniel,
Thank you for feedback.
No success with iio_info…
Then I did install Iibiio.
Then I did install libad9361-iio
Still the same error (segmenation fault at --probe…)
Then I found this at this adress:
Important note
Currently the main branch of this repository does not support the new v1.0 API of libiio.
If you want to build libad9361-iio please use the libad9361-iio-v0 branch that supports the old v0.x API, that can be found on the libiio-v0 branch or as packages on the release section of the libiio repository.
After installing the branch to “old” libiio-v0 all the command with --probe…
does show the Pluto again!
Here something did happen…
Best regards
Armin
HB9MFL
