We received a telemetry frame from long-lost (or so we thought) TTU101 today with two receivers (operated ES5EC and ES5TO) that are currently used for TTU100 downlink. We dont know how frequent the transmissions may be, and #44401 is just a best guess candidate object, but the telemetry could be transmitted at any time and anywhere. TTU101 callsign is ES1ZWS
Telemetry frame payload after AX25 header has this structure (uint16-s are little endian):
typedef struct
uint16_t
u_obc_m, // main OBC power rail volage, mV
u_obc_b, // backup OBC power rail voltage, mV
u_comx, // xband transmitter power rail voltage, mV
u_com, // UHF radio power rail voltage, mV
u_adcs, // ADCS power rail voltage, mV
u_beacon, // backup radio power rail voltage, mV
u_sol, // solar cell power rail (input to EPS) voltage, mV
u_bata, // battery A voltage, mV
i_obc, // main OBC consumed current, mA
u_radsens1, // radiation sensor 1 measured voltage, mV
u_radsens2, // radiation sensor 2 measured voltage, mV
u_radref, // radiation sensor reference measured voltage, mV
com_resets; // COM module power-cycled counter due to unresponsiveness
uint8_t
eps_status, // latest received EPS status (in response to keepalive)
eps_checks,
com_checks, // number of pings sent to COM from last reset or response
obcm_checks, // number of pings sent to main OBC since last response
obcb_checks; // number of pings sent to backup OBC since last response
} telemetry_t;
