Pi3 to hot / to slow ./ to busy?
Hi, last week I made a little change to station 1441 , my 403 MHz home station. I changed the antenna, it was connected to the LogPer which I need monday so I connected it to the horizontal single 380-420 MHz dipole. Scheduled some obs, which all failed. The satellite signals where visible, but not doppler corrected and my local birdies all where straight lines.
So I did the usual update, upgrade, satnogs-setup updae, apply and after that reboot.
Scheduled some more obs, which look better but still most of the satellites have a “bump” in there observations.
This one looks great:
But this one does not
https://network.satnogs.org/observations/10015630/
Neither does this one
https://network.satnogs.org/observations/10015619/
It’s about 36 degrees celcius where the Pi is hanging around.
Any idea what to check ?
Thanks,
Ben
pe2bz@raspberrypi:~ $ cat /sys/class/thermal/thermal_zone0/temp
62322
which makes 62 degrees Celsius
The doppler mismatch could be the clock on the pi being off.
