Good Day Everyone,
I’ve gotten my station up and running, however, I seem to be encountering an issue with my recordings. There is a periodic and consistent bar where there’s almost no received signal coming into the radio every ~60 seconds. The surrounding frequencies have been checked, but there appears to be no strong signal that corresponds to the ~60 second period. Is there an internal setting that could be causing the RTL-SDR Blog V4 to shut down or reduce gain drastically? Station 3581 near me has also experienced this same issue, but is running an RTL-SDR Blog V3.
Thank you so much for your assistance. Below is an example w/ metadata:
radio: {
version: "v2.3-compat-xxx-v2.3.5.0",
parameters: {
soapy-rx-device: "driver=rtlsdr",
samp-rate-rx: "2.048e6",
rx-freq: "137620000",
file-path: "/tmp/.satnogs/data/receiving_satnogs_9812988_2024-07-08T23-37-04.out",
waterfall-file-path: "/tmp/.satnogs/data/receiving_waterfall_9812988_2024-07-08T23-37-04.dat",
decoded-data-file-path: "/tmp/.satnogs/data/receiving_data_9812988_2024-07-08T23-37-04.png",
doppler-correction-per-sec: null,
lo-offset: null,
ppm: null,
rigctl-port: "4532",
gain-mode: "Overall",
gain: "49.6",
antenna: "RX",
dev-args: null,
stream-args: null,
tune-args: null,
other-settings: null,
dc-removal: null,
bb-freq: null,
bw: null,
enable-iq-dump: "0",
iq-file-path: null,
udp-dump-host: null,
udp-dump-port: 57356,
wpm: null,
baudrate: null,
framing: null
latitude: 45.96299067991878,
longitude: -66.62266471226759,
elevation: 12,
frequency: 137620000
