Hi…
something happen on Pass Prediction listing on my station…?
I looked on other stations and have normal ~24hrs predictions but
only few predictions (around 10) on my own station. (log in or log out)
Any idea…? (same on 2 diff PC)
When I clicked on ‘Calculate’ for your station, I also only see about 10 future observations available that are no more than 10 minutes from the current time. Hmm.
The last one listed, (SOAR in this case) for your station, shows no plot for the observation - maybe that’s a clue to go on for the developers.
What happens when you try scheduling 1+ hours out via satnogs-auto-scheduler?
Scott
update:
Error appears to be with SOAR for some reason. I tried scheduling at your station again just now and SOAR was the last shown available observation (with no trajectory plotted),
So I then tried to schedule a SOAR observation at my station 2134 and got this:
So that’s 15 future observations for SOAR in the next 4 hours. SNAFU
Not sure if it’s the TLE’s for SOAR, maybe it re-entered??
Blockquote
I don’t know wha’t happen, but back to normal for now…
ve2dsk
@satcolintel5 You debug was right, SOAR was re-entered so the last TLE set was causing this issue. I’ve suggested and approved the change in DB and now the issue is fixed as @ve2dsk noted.
Hello, I’m having the same issue on my station (1650), I only get predictions for 40 minutes instead the usual 24 hrs, it appears that the loading process somehow becomes stalled and keeps trying to load the pass predictions without ending, any suggestions on how to proceed to fix the issue?
Thanks in advance & best Regards,
Abraham - XE3ADC
Probably a decayed satellite, give me some minutes to check.
I have fixed some of the decayed satellites but it seems that there is still an issue. I’m checking to find out which satellite causes this.
Thanks Fredy, Having passed the 40 minutes I tried again and now I’m getting pass predictions for 9 hours, in both cases the last prediction loaded was for Bricsat-2.
On the most recent try, the Bricsat-2 prediction was at 22:33 on 04/21/22 UTC, with 9 deg max elevation and there is no path shown in the polar plot.
Best regards,
Abraham - XE3ADC
Indeed BRICSAT-2 was decayed yesterday or today. Now the station page loads right.
Thanks Fredy, yes.!.. I just tried, the pass predictions loaded as normal.
I did not try with auto-schedule, I wonder what would have happened…
Best Regards,
Abraham - XE3ADC
Another one causing an issue… ve2dsk
