I’m Muhammet Emin, a 17-year-old student from Türkiye. I built a free, open-source web app that shows the whole tracked catalogue (~12,000 objects) on a 3D globe, and I added a Radio panel for people who want to receive satellites:
Filter by band (2 m, 70 cm, 400 MHz, 137 MHz weather, “easy VHF/UHF”…) and mode (FM, CW, SSB, digital)
“Amateur only” and “Above my horizon now” with a minimum-elevation setting
Next pass time and max elevation for your location
Link from each satellite to its recent SatNOGS observations
CSV export and shareable filter links
Frequencies come from the SatNOGS DB (CC BY-SA 4.0), only transmitters marked active and alive, plus the AMSAT active-frequency list. Passes are computed in the browser with SGP4 from CelesTrak TLEs, so times can be off by a little.
You can also see historical collisions that took place in the past, close approaches, recent launches and future projection. Furthermore, I believe that we can create an awareness for the crowd in Earth’s orbit.
I’d really value your feedback: what would make this useful on an actual pass? If you spot a wrong frequency, there’s a form for that on GitHub, and I’ll also report it back to SatNOGS DB.
Thanks for SatNOGS. This wouldn’t exist without your open data!
Good evening, thanks for your energy in this project
What I notice: Crowded image till I de-select debris and set max altitude to about 1100 km. That would be better to start with and have the user add what he likes to see.
Also noticed: entering ISS in the Search Objects does show no output, the norad id 25544 does show.
Entered ao-73 which popped up but on the right side it shows that’s from Norwegian, a leftover from the previous satellite which I had selected (Norsat 1 from my mind)
As personal preference, I would like the right “object” part to jump to the top showing the satellite name / info when I select a new satellite from the sky.
And for the less color sensitive, I tried with an 78 year old radio amateur, he can’t tell the difference between blue (starlinks) and green (other) .
Nice to have the frequencies in the satellite info, can you generate a special / different symbol / colour for radio amateur satellites ?
Thanks for you valuable feedback Ben, I will try to fix these issues soon. Additionally, contrary to your phrase, I saw that when I entered “ISS” in the search section, ISS was listed in there. Maybe you might used a filter while searching it. In my opinion, you couldn’t see ISS because of filter.
Thanks Muhammet, I did assume “stations” would be listeners on the map, but those are ISS and the chinese one ? I cannot select satellites and stations, without showing debris, that’s why I had that set to “satellites” and indeed the ISS does not pop up in the results
Thanks, you are right, IO-86 is missing. CelesTrak currently publishes no orbit data for it, which is where my app gets TLEs. I’ll add SatNOGS DB as a fallback for amateur satellites like this, with a note that its orbit data is less fresh. 73!
