Can you please inform me what is the opening angle for the SatNOGS broadcast cone?
Thanks in advance,
~marios
Note: To be more clear , the opening angle is θ in the image below
Thanks in advance,
~marios
Depends on the antenna used. For some of our antennas this is ~15-20 degrees for each direction (V-H).
If you take the tracker movement into account on top of that, then it is beyond 180 degrees. (essentially the whole hemisphere)
I just need it to figure out how many of them we need to cover LEO
Your main concern (and variable) would then be the minimum satellite altitude you are going for. I suggest 300km (thus we have the majority of items covered)
Cheers!
According to wikipedia LEO starts from 160km up to 2000km, so 300km will be ok.
Btw, I am trying to set a linear program (which would take into consideration lots of constraints) so as to minimize overlapping areas between stations and then decide on the possible locations.
