I don’t know if this is related but I’m getting a bunch of 403’s with error log level “INFO”.
Feb 07 13:27:23 raspberrypi satnogs-client[12224]: 2020-02-07 13:27:23,209 - apscheduler.scheduler - INFO - Added job “spawn_observer” to job store “default”
Feb 07 13:27:23 raspberrypi satnogs-client[12224]: 2020-02-07 13:27:23,214 - satnogsclient.scheduler.tasks - INFO - Adding new job: 1660334
Feb 07 13:27:23 raspberrypi satnogs-client[12224]: 2020-02-07 13:27:23,218 - apscheduler.scheduler - INFO - Added job “spawn_observer” to job store “default”
Feb 07 13:27:23 raspberrypi satnogs-client[12224]: 2020-02-07 13:27:23,223 - satnogsclient.scheduler.tasks - INFO - Adding new job: 1660338
Feb 07 13:27:23 raspberrypi satnogs-client[12224]: 2020-02-07 13:27:23,228 - apscheduler.scheduler - INFO - Added job “spawn_observer” to job store “default”
Feb 07 13:27:23 raspberrypi satnogs-client[12224]: 2020-02-07 13:27:23,230 - apscheduler.executors.default - INFO - Job “get_jobs (trigger: interval[0:01:00], next run at: 2020-02-07 13:28:22 UTC)” executed successfully
Feb 07 13:27:23 raspberrypi satnogs-client[12224]: 2020-02-07 13:27:23,712 - satnogsclient.scheduler.tasks - ERROR - Bad status code: 403
Feb 07 13:27:23 raspberrypi satnogs-client[12224]: 2020-02-07 13:27:23,713 - satnogsclient.scheduler.tasks - INFO - Trying to PUT observation data for id: 1660332
Feb 07 13:27:27 raspberrypi satnogs-client[12224]: 2020-02-07 13:27:27,143 - satnogsclient.scheduler.tasks - ERROR - Bad status code: 403
Feb 07 13:27:27 raspberrypi satnogs-client[12224]: 2020-02-07 13:27:27,144 - satnogsclient.scheduler.tasks - INFO - Trying to PUT observation data for id: 1660269
Feb 07 13:27:28 raspberrypi satnogs-client[12224]: 2020-02-07 13:27:28,260 - satnogsclient.scheduler.tasks - ERROR - Bad status code: 403
Feb 07 13:27:28 raspberrypi satnogs-client[12224]: 2020-02-07 13:27:28,264 - satnogsclient.scheduler.tasks - INFO - Trying to PUT observation data for id: 1660269
Feb 07 13:27:32 raspberrypi satnogs-client[12224]: 2020-02-07 13:27:32,584 - satnogsclient.scheduler.tasks - ERROR - Bad status code: 403
Feb 07 13:27:32 raspberrypi satnogs-client[12224]: 2020-02-07 13:27:32,589 - satnogsclient.scheduler.tasks - INFO - Trying to PUT observation data for id: 1660331
Feb 07 13:27:33 raspberrypi satnogs-client[12224]: 2020-02-07 13:27:33,568 - satnogsclient.scheduler.tasks - ERROR - Bad status code: 403
Feb 07 13:27:33 raspberrypi satnogs-client[12224]: 2020-02-07 13:27:33,573 - satnogsclient.scheduler.tasks - INFO - Trying to PUT observation data for id: 1660331
Feb 07 13:27:35 raspberrypi satnogs-client[12224]: 2020-02-07 13:27:35,533 - satnogsclient.scheduler.tasks - ERROR - Bad status code: 403
Feb 07 13:27:35 raspberrypi satnogs-client[12224]: 2020-02-07 13:27:35,540 - satnogsclient.scheduler.tasks - INFO - Trying to PUT observation data for id: 1660270
Feb 07 13:27:39 raspberrypi satnogs-client[12224]: 2020-02-07 13:27:39,205 - satnogsclient.scheduler.tasks - ERROR - Bad status code: 403
Feb 07 13:27:39 raspberrypi satnogs-client[12224]: 2020-02-07 13:27:39,210 - satnogsclient.scheduler.tasks - INFO - Trying to PUT observation data for id: 1660337
Feb 07 13:27:40 raspberrypi satnogs-client[12224]: 2020-02-07 13:27:40,763 - satnogsclient.scheduler.tasks - ERROR - Bad status code: 403
Feb 07 13:27:40 raspberrypi satnogs-client[12224]: 2020-02-07 13:27:40,768 - satnogsclient.scheduler.tasks - INFO - Trying to PUT observation data for id: 1660330
Feb 07 13:27:42 raspberrypi satnogs-client[12224]: 2020-02-07 13:27:42,861 - satnogsclient.scheduler.tasks - ERROR - Bad status code: 403
Feb 07 13:27:42 raspberrypi satnogs-client[12224]: 2020-02-07 13:27:42,867 - satnogsclient.scheduler.tasks - INFO - Trying to PUT observation data for id: 1660332
Feb 07 13:27:43 raspberrypi satnogs-client[12224]: 2020-02-07 13:27:43,927 - satnogsclient.scheduler.tasks - ERROR - Bad status code: 403
Feb 07 13:27:43 raspberrypi satnogs-client[12224]: 2020-02-07 13:27:43,931 - satnogsclient.scheduler.tasks - INFO - Trying to PUT observation data for id: 1660337
Feb 07 13:27:45 raspberrypi satnogs-client[12224]: 2020-02-07 13:27:45,185 - satnogsclient.scheduler.tasks - ERROR - Bad status code: 403
Feb 07 13:27:45 raspberrypi satnogs-client[12224]: 2020-02-07 13:27:45,189 - satnogsclient.scheduler.tasks - INFO - Trying to PUT observation data for id: 1660330
Feb 07 13:27:46 raspberrypi satnogs-client[12224]: 2020-02-07 13:27:46,327 - satnogsclient.scheduler.tasks - ERROR - Bad status code: 403
Feb 07 13:27:46 raspberrypi satnogs-client[12224]: 2020-02-07 13:27:46,345 - apscheduler.executors.default - INFO - Job “post_data (trigger: interval[0:02:00], next run at: 2020-02-07 13:29:22 UTC)” executed successfully
Feb 07 13:28:22 raspberrypi satnogs-client[12224]: 2020-02-07 13:28:22,753 - apscheduler.executors.default - INFO - Running job “get_jobs (trigger: interval[0:01:00], next run at: 2020-02-07 13:29:22 UTC)” (scheduled at 2020-02-07 13:28:22.750445+00:00)
Feb 07 13:28:22 raspberrypi satnogs-client[12224]: 2020-02-07 13:28:22,754 - satnogsclient.scheduler.tasks - INFO - Get jobs started
Feb 07 13:28:22 raspberrypi satnogs-client[12224]: 2020-02-07 13:28:22,755 - satnogsclient.scheduler.tasks - INFO - Trying to GET observation jobs from the network
Feb 07 13:28:23 raspberrypi satnogs-client[12224]: 2020-02-07 13:28:23,154 - satnogsclient.scheduler.tasks - INFO - Adding new job: 1660553
Feb 07 13:28:23 raspberrypi satnogs-client[12224]: 2020-02-07 13:28:23,157 - apscheduler.scheduler - INFO - Added job “spawn_observer” to job store “default”
Feb 07 13:28:23 raspberrypi satnogs-client[12224]: 2020-02-07 13:28:23,161 - satnogsclient.scheduler.tasks - INFO - Adding new job: 1660552
Feb 07 13:28:23 raspberrypi satnogs-client[12224]: 2020-02-07 13:28:23,164 - apscheduler.scheduler - INFO - Added job “spawn_observer” to job store “default”
Feb 07 13:28:23 raspberrypi satnogs-client[12224]: 2020-02-07 13:28:23,167 - satnogsclient.scheduler.tasks - INFO - Adding new job: 1660550
Feb 07 13:28:23 raspberrypi satnogs-client[12224]: 2020-02-07 13:28:23,170 - apscheduler.scheduler - INFO - Added job “spawn_observer” to job store “default”
Feb 07 13:28:23 raspberrypi satnogs-client[12224]: 2020-02-07 13:28:23,174 - satnogsclient.scheduler.tasks - INFO - Adding new job: 1660549
Feb 07 13:28:23 raspberrypi satnogs-client[12224]: 2020-02-07 13:28:23,178 - apscheduler.scheduler - INFO - Added job “spawn_observer” to job store “default”
Feb 07 13:28:23 raspberrypi satnogs-client[12224]: 2020-02-07 13:28:23,182 - satnogsclient.scheduler.tasks - INFO - Adding new job: 1660334
Feb 07 13:28:23 raspberrypi satnogs-client[12224]: 2020-02-07 13:28:23,186 - apscheduler.scheduler - INFO - Added job “spawn_observer” to job store “default”
Feb 07 13:28:23 raspberrypi satnogs-client[12224]: 2020-02-07 13:28:23,190 - satnogsclient.scheduler.tasks - INFO - Adding new job: 1660338
Feb 07 13:28:23 raspberrypi satnogs-client[12224]: 2020-02-07 13:28:23,194 - apscheduler.scheduler - INFO - Added job “spawn_observer” to job store “default”
Feb 07 13:28:23 raspberrypi satnogs-client[12224]: 2020-02-07 13:28:23,196 - apscheduler.executors.default - INFO - Job “get_jobs (trigger: interval[0:01:00], next run at: 2020-02-07 13:29:22 UTC)” executed successfully
CW demodulation should become better once the new version of gr-satnogs is released more widely on production for stations to deploy (our test stations are reporting good results with it). Also your signals seem kinda weak overall, please check your antenna and/or LNA
also the first errors you posted are unrelated (and should disappear with an update soon)
As for the second set of errors seems like a mistake on your API key? Can you check?
Thank you so much for getting back to me! I really appreciate it! I got disconnected on freenode.
I’m just confused as some of the observations have quite strong signals - and others of course not. But out of 100 observations not a single one was demodulated other than NOAA. And they are certainly strong enough that fldigi is able to decode them. Would I get an error if demodulation wasn’t running?
Can I test it manually? I noticed the satnogs_cw_decoder.py script. Can I manually use that with the observation ogg files to test? I can’t seem to figure out if it’s possible or the relevant syntax?
API key correct, so the 403’s make no sense. I also doubt NOAA would demodulate and upload fine if that was the issue.
Yeah, absolutely false demodulations. I was just expecting I would at least get a few of those instead of no data at all for anything but NOAA. Also have a bunch of 70cm observations that also look like they would at least get a partial demod. A lot of AAUSAT4 ones that I usually don’t have issues decoding with hs_soundmodem for instance.
I hear you saying that my setup is probably working as intended though, so I will work on improving my reception. … and build a rotator.
I think you are using a dipole +LNA… Where is located the LNA?
Could you try using another antena without LNA?
Or even the dipole without LNA?
Sometimes the LNA is not a help…
Look at my station, is running without LNA, right now with a vertical antenna https://network.satnogs.org/stations/342/
The LNA is connected before the coax, running off the RTL-SDR biasT. It’s not giving me much but it is giving me something. It a generic 5V thing but I think I’ll test with a 12v LNA+external biasT soon.
I have a nanoVNA coming - hopefully that can tell me something I don’t know about my antenna.
Also - I’m surrounded by taller buildings so I need pretty good passes.
Maybe my dev-args for enabling the biasT is messing things up without giving any errors but I can’t seem to dig deep enough to figure out if it’s affecting demodulation.
I see a cw_to_symbol warning - what does this mean?
Feb 12 08:43:11 raspberrypi satnogs-client[2604]: [WARNING] /usr/src/packages/BUILD/lib/cw_to_symbol_impl.cc:112: Dot symbol samples: 654
In context:
Feb 12 08:43:09 raspberrypi satnogs-client[2604]: Traceback (most recent call last):
Feb 12 08:43:09 raspberrypi satnogs-client[2604]: File “/usr/lib/python2.7/threading.py”, line 801, in __bootstrap_inner
Feb 12 08:43:09 raspberrypi satnogs-client[2604]: self.run()
Feb 12 08:43:09 raspberrypi satnogs-client[2604]: File “/usr/lib/python2.7/threading.py”, line 754, in run
Feb 12 08:43:09 raspberrypi satnogs-client[2604]: self.__target(*self.__args, **self.__kwargs)
Feb 12 08:43:09 raspberrypi satnogs-client[2604]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/satnogsclient/observer/worker.py”, line 112, in _communicate_tracking_info
Feb 12 08:43:09 raspberrypi satnogs-client[2604]: self.send_to_socket(pin, sock)
Feb 12 08:43:09 raspberrypi satnogs-client[2604]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/satnogsclient/observer/worker.py”, line 198, in send_to_socket
Feb 12 08:43:09 raspberrypi satnogs-client[2604]: position = sock.send(“p\n”).split(’\n’)
Feb 12 08:43:09 raspberrypi satnogs-client[2604]: File “/var/lib/satnogs/local/lib/python2.7/site-packages/satnogsclient/observer/commsocket.py”, line 81, in send
Feb 12 08:43:09 raspberrypi satnogs-client[2604]: response = self.sock.recv(self._tasks_buffer_size).decode(‘ascii’)
Feb 12 08:43:09 raspberrypi satnogs-client[2604]: error: [Errno 107] Transport endpoint is not connected
Feb 12 08:43:11 raspberrypi satnogs-client[2604]: [WARNING] /usr/src/packages/BUILD/lib/cw_to_symbol_impl.cc:113: Window size: 109
