I am interested in experimenting with dashboard construction. How do I gain the user permissions to do so?
Thanks in advance.
Red
KC4LE
Thanks in advance.
Red
KC4LE
PM me your registered email address and I will escalate your privileges. I can give some hints, too.
Ok, that was not as private as expected
Working on it! Please login to the SSO System used on all our pages and visit the grafana dashboards at least once while logged in!
Hello @DL4PD , I also want to make a dashboard for our upcoming cubesat (MySat-2). Can you also give me persmissions? hamze.j.i@gmail.com (I know that’s not private either, but I’m in a rush here )
First of all you need to login into the dashboard website and after that I can escalate you privileges!
I did login with the same email.
Sorry those were busy times.
I just added you to the Scratchpad Editors team.
You are free to build a dashboard inside the Scratchpad folder.
Once you are ok to have it publicly available just let me know and I will place it in “Telemetry”. This will automatically make it availbale publicly. Of course you will still be able to edit this after moving.
By the way: Is there a a satnogs-decoder
already available for MySat-2?
Thank you so much!
Regarding the decoder, I’m working on it, but the beacon structure itself is still under development, so I won’t submit the decoder (and of course the dashboard) until we finish developing the the cubesat and agree on the telemetry and beacon.
it would be good to have an early view on your decoder - so you could probably push a MR marked as “Draft”. This would make the available time to fix basic mistakes bigger.
Let me know if I can be of help on any topic…
@DL4PD I’m sorry if this is not the right place to post this but I want to somehow let the SatNogs community know that MeznSat changed its datarate to 4800. How can I relay that information to the stations?
@hamzeissa you can indicate this change by suggesting the necessary changes (active/inactive transmitter) on the satellite transmitters page in db.satnogs.org. If the transmitter with that baudrate doesn’t exist, please create a new one. Let us know if you have any issues on following this process.
@fredy Thanks a lot for the info. I added the new 4800 transmitter as “active” and set the previous 2400 as inactive. Now waiting for the moderator’s confirmation
Hi, I am also interested to build dashboard, How do I gain user permissions to do?
I did login with same email in LSF and Grafana
email: pavani.mundra@studentmail.unicas.it
Thanks in advance
Thank You
Which satellites are you interested in?
Thanks for the Immediate response.
I am interested in Mitee Satellite, because Mitee is more similar to our satellite, we are planning to use satnogs platform.
We are collecting all the requirements to collaborate with satnogs.
Do I require a ground station to create a dashboard?
Please provide me access to create the dashboard.
Thank You
Hi @pavanimundra apparently my email about your request hasn’t reached you.
Please create an issue in the following address:
I am also interested to build dashboard for QMR-KWT CubeSat for OrbitalSpace Team, How do I gain user permissions to do?
I did login with the same email in Grafana
email: Nourah.Alfialy@gmail.com
Thanks
