Anybody has an idea if decoded data from observations done by satnogs groundstations are uploaded to the dB? I don’t think so because there is no callsign(name)/location code defined for a GS?
We have implemented this functionality and it is under testing in network-dev and db-dev. It’s going to be deployed in production soon, after finishing with some changes in db and network code.
Great work and maybe not as easy as it looks
Yes, the name of your ground station will show up (as well as the grid square). For instance, here is a packet in db-dev that was sourced from network-dev, originating by https://network-dev.satnogs.org/stations/108/ (you’ll notice the source is not “sids” but rather “network” in this case)
"norad_cat_id": 43017,
"transmitter": "",
"source": "network",
"schema": "",
"decoded": "",
"frame": "AA0038A90720FF6FDB80ED8ED6888E036B88FFBFDCC9CDDBC1CDDB6FA8866718875AC885A0FFFF0D4C8C8E9894CD92ABA5AAA505A0CE3D00008814000D570628",
"observer": "SR1GEO_DEV01-JO73mi",
"timestamp": "2018-09-15T11:02:37Z"
