@fredy I’m still having this problem with my station 858 for some observations. I have changed both power supply and USB power cable to the RPI. I also measured the power current to the RPI and it is way below 2.5 ampere.
The problem started 20 june after I did a “Update” in the configuration tool. Before that I had several month without any failed observations. Installed versions are:
satnogs-client-ansible-202209101521, satnogs-client-1.8.1, satnogs-flowgraphs-1.4-1
Any ideas what can be the problem?
