Observation 988: GOMX 1 (39430)
Regarding Observation 988 …
Decoded using gr-satellites GOMX-1.
Decoded frames 28.
More frames.
Timestamp: 2017-02-07 12:06:59
Flags: 0x79
Beacon A:
  • OBC:
    Boot count: 2026
    Board temp 1: 19.0ºC
    Board temp 2: 21.0ºC
    Panel temps: [0.0, 3.75, 11.25, 19.75, 17.5, 22.5]ºC
  • COM:
    Bytes corrected by RS: 0
    RX packets: 1
    RX errors: 1
    TX packets: 622
    Last temp A: 22ºC
    Last temp B: 22ºC
    Last RSSI: 0dBm
    Last RF error: 0Hz
    Last battery voltage: 8.4V
    Last TX current: 842mA
    Boot count: 4531
  • EPS:
    Boost converter voltages: [7.111, 7.098, 0.006]V
    Battery voltage: 8.289V
    Current out: (69, 2, 155, 38, 5, 0)mA
    Current in: (22, 21, 345)mA
    Boost converter current: 10mA
    Battery current: 139mA
    Temperature sensors: (22, 23, 21, 21, 21, 20)ºC
    Output status: 0x1d
    EPS reboots: 0
    WDT I2C reboots: 172
    WDT GND reboots: 326
    Boot cause: 4
    Latchups: (0, 0, 0, 0, 0, 0)
    Battery mode: invalid mode 3
  • GATOSS:
    Average FPS 5min: 0
    Average FPS 1min: 0
    Average FPS 10sec: 0
    Plane count: 0
    Frame count: 0
    Last ICAO: 0x0
    Last timestamp: 1970-01-01 00:00:00
    Last latitude: 0.0
    Last longitude: 0.0
    Last altitude: 0ft
    CRC corrected: 0
    Boot count: 0
    Boot cause: 0
  • HUB:
    Temp: 17ºC
    Boot count: 885
    Reset cause: 3
    Switch status: 0xfc
    Burn tries: (1, 1)
  • ADCS:
    Tumble rate: (-2.904052734375, 1.3072967529296875, -1.5111541748046875)
    Tumble norm: (4.380458831787109, 0.5632920861244202)
    Magnetometer: (-424.053466796875, 225.443359375, -140.12289428710938)
    Status: 0x3
    Torquer duty: (85.0, -85.0, 85.0)
    ADS state: 0x22
    ACS state: 0x22
    Sun sensor: (4, 5, 72, 48, 65, 0, 0, 2)
  • CSP header:
    Priority: 2
    Source: 1
    Destination: 10
    Destination port: 30
    Source port: 0
    Reserved field: 0
    HMAC: 0
    XTEA: 0
    RDP: 0
    CRC: 0
