Regarding Observation 9873098 …
Does this look like a downlink transmit? @SA2KNG
It doesn’t look like the same transmitter, it has two distinct edges and weak trace in the center.
Like obs 9473199
Probably it is a LEMUR at that frequency. It will need some investigation to find which one is, as it seems we haven’t it in SatNOGS DB.
@SA2KNG Thanks for the comment, Any chance you are able to upload the spe-can waterfall for this pass for observation:
2024-07-17 15:50:50
2024-07-17 15:58:23
Thank you very much ![]()
Max El on this pass was 5 and on Obs 9473199 max el was 52 deg so possibly not as strong as a signal strength due to elevation constrains? Just thinking outloud thanks!
Thank you for the comment! Can pull the TLE’s and plot them in respect to LEO-1 to see if there was one in visible range during that timestamp ![]()
Do note that station 1888 is running other software to record Impulse-1, so all the satnogs observations is there to block access so any other observations doesn’t suddenly get interrupted.
This is the waterfall from 15:50 that would have been #9873100
Thank you very much! Does the zoomed in portion here represent accurate Downlink transmit from the satellite? Thanks!
Did that with ikhnos and none of the known satellites near Impulse-1 frequency, neither the Impulse-1, fit the signal curve. For example here is Impulse-1 expected curve:
Thank you! The frequency, though shifted, in this picture below looks to follow that signature from the curve you drew up right? thanks! @fredy
Unfortunately this isn’t Impulse-1:
SatNOGS Network - Observation 9656721
@fredy @SA2KNG this observation shows a similar style of beacon activity with the same intensity as the one listed above… thoughts? Different pass geometry traveled between the two passes
