Regarding Observation 9684537 …
Why did the data collected during the observation after a week fail and cannot be opened again? the information written is that it failed, and the data did not come out.
“versions”: {
“satnogs-client”: “1.8.1”,
“gr-satnogs”: “2.3.5.0-1”,
“gr-soapy”: “2.1.3.1-1”,
“gnuradio”: “3.8.2.0-14”,
“satnogs-config”: “0.13.2”
“state”: {
“is-applied”: true,
“pending-tags”: null
“system”: {
“date”: “2024-06-20T09:06:36.562447+00:00”,
“distribution”: {
“RELEASE”: “11”,
“CODENAME”: “bullseye”,
“ID”: “Raspbian”
“pending-updates”: false,
“platform”: {
“system”: “Linux”,
“node”: “raspberrypi”,
“release”: “6.1.21-v7+”,
“version”: “#1642 SMP Mon Apr 3 17:20:52 BST 2023”,
“machine”: “armv7l”
“memory”: {
“total”: 966750208,
“available”: 787410944,
“percent”: 18.6,
“used”: 118194176,
“free”: 364171264,
“active”: 369557504,
“inactive”: 156839936,
“buffers”: 43962368,
“cached”: 440422400,
“shared”: 729088,
“slab”: 45473792
“disk”: {
“total”: 15339065344,
“used”: 4523397120,
“free”: 10138198016,
“percent”: 30.9
“configuration”: {
“hamlib_utils_rot_enabled”: true,
“hamlib_utils_rot_opts”: “-m 204 -s 19200 -r /dev/ttyACM0 -C timeout=200”,
“satnogs_antenna”: “RX”,
“satnogs_artifacts_api_token”: “[redacted]”,
“satnogs_dev_args”: “serial”,
“satnogs_log_level”: “DEBUG”,
“satnogs_rf_gain”: “SoapySDRUtil --probe”,
“satnogs_rot_baud”: “9600”,
“satnogs_rot_model”: “ROT_MODEL_NETROTCTL”,
“satnogs_rot_port”: “localhost:4533”,
“satnogs_rx_bandwidth”: “24000”,
“satnogs_station_elev”: “665”,
“satnogs_station_id”: “3587”,
“satnogs_station_lat”: “-6.975504”,
“satnogs_station_lon”: “107.6293934”
Press Enter to continue…
Good morning,
Let see info find here:
RTL-SDR V3 sir
Actually, how does the process and step-by-step of satellite data acquisition work?
After testing the satellite data acquisition, the audio meta data and waterfall appeared at night. However, after a week, when I checked again, the data failed.
@nhanifah13 Why did you put this value?
EDIT:
I guess you were confused by this description here:
https://wiki.satnogs.org/SatNOGS_Client_Setup
RF Gain value for your SDR hardware.
Run
to see all possible gain values for your hardware. Example: For RTL-SDR without pre-amp, 32.8 is a good starting value. Follow Setting the gain to find a good gain value.
So for the SATNOGS_RF_GAIN
you either run in command line the command SoapySDRUtil --probe
and you get numeric values that your SDR support, or you put directly numeric values, as the example say for your rtlsdr you can start with the value 32.8
Please read carefully the following page
Run SoapySDRUtil --probe
So, my advice is to check all the settings according the documention.
First, please check the correct installation.
Please run
$ systemctl status satnogs-client
and read following:
and
https://wiki.satnogs.org/Understanding_satnogs-flowgraphs
