The station is in testing mode. Haven’t changed any gain settings yet. I din’t try to go back to the v-dipole.
I replaced the pi with another one. And just connected the antenna with RTLSDR without any LNA.
Please look at this observation. Is it working now?
(http://network.satnogs.org/observations/895982/)
I will add the whole errors log as well:
Aug 06 17:24:56 raspberrypi satnogs-client[632]: 2019-08-06 17:24:56,101 - satno gsclient - ERROR - Cannot connect to socket 127.0.0.1:4533
Aug 06 17:24:56 raspberrypi satnogs-client[632]: linux; GNU C++ version 6.2.0 20 161010; Boost_106100; UHD_003.009.005-0-unknown
Aug 06 17:24:56 raspberrypi satnogs-client[632]: 2019-08-06 17:24:56,138 - satno gsclient - ERROR - Cannot connect to socket 127.0.0.1:4533
Aug 06 17:24:56 raspberrypi satnogs-client[632]: Exception in thread Thread-2:
Aug 06 17:24:56 raspberrypi satnogs-client[632]: Traceback (most recent call las t):
Aug 06 17:24:56 raspberrypi satnogs-client[632]: File “/usr/lib/python2.7/thre ading.py”, line 801, in __bootstrap_inner
Aug 06 17:24:56 raspberrypi satnogs-client[632]: self.run()
Aug 06 17:24:56 raspberrypi satnogs-client[632]: File “/usr/lib/python2.7/thre ading.py”, line 754, in run
Aug 06 17:24:56 raspberrypi satnogs-client[632]: self.__target(*self.__args, **self.__kwargs)
Aug 06 17:24:56 raspberrypi satnogs-client[632]: File “/var/lib/satnogs/local/ lib/python2.7/site-packages/satnogsclient/observer/worker.py”, line 134, in _com municate_tracking_info
Aug 06 17:24:56 raspberrypi satnogs-client[632]: self.send_to_socket(p, sock )
Aug 06 17:24:56 raspberrypi satnogs-client[632]: File “/var/lib/satnogs/local/ lib/python2.7/site-packages/satnogsclient/observer/worker.py”, line 180, in send _to_socket
Aug 06 17:24:56 raspberrypi satnogs-client[632]: position = sock.send(“p\n”) .split(’\n’)
Aug 06 17:24:56 raspberrypi satnogs-client[632]: File “/var/lib/satnogs/local/ lib/python2.7/site-packages/satnogsclient/observer/commsocket.py”, line 76, in s end
Aug 06 17:24:56 raspberrypi satnogs-client[632]: self.s.send(message)
Aug 06 17:24:56 raspberrypi satnogs-client[632]: error: [Errno 32] Broken pipe
Aug 06 17:25:00 raspberrypi satnogs-client[632]: gr-osmosdr 0.1.4 (0.1.4) gnurad io 3.7.10
Aug 06 17:25:00 raspberrypi satnogs-client[632]: built-in source types: file osm osdr fcd rtl rtl_tcp uhd miri hackrf bladerf rfspace airspy soapy redpitaya
Aug 06 17:25:00 raspberrypi satnogs-client[632]: Using device #0 Realtek RTL2838 UHIDIR SN: 00000001
Aug 06 17:25:00 raspberrypi satnogs-client[632]: Using 32 buffers of size 16384.
Aug 06 17:25:00 raspberrypi satnogs-client[632]: Found Rafael Micro R820T tuner
Aug 06 17:25:00 raspberrypi satnogs-client[632]: [R82XX] PLL not locked!
Aug 06 17:25:00 raspberrypi satnogs-client[632]: Exact sample rate is: 1000000.0 26491 Hz
Aug 06 17:25:01 raspberrypi satnogs-client[632]: [R82XX] PLL not locked!
Aug 06 17:25:01 raspberrypi satnogs-client[632]: /var/lib/satnogs/.gnuradio/pref s/vmcircbuf_default_factory: No such file or directory
Aug 06 17:25:01 raspberrypi satnogs-client[632]: vmcircbuf_createfilemapping: cr eatefilemapping is not available
Aug 06 17:25:01 raspberrypi satnogs-client[632]: gr::vmcircbuf_sysv_shm: shmat ( 2): Invalid argument
Aug 06 17:25:38 raspberrypi satnogs-client[632]: 2019-08-06 17:25:38,206 - apscheduler.executors.default - INFO - Running job “get_jobs (trigger: interval[0:01:00], next run at: 2019-08-06 14:25:38 UTC)” (scheduled at 2019-08-06 14:25:38.155206+00:00)
Aug 06 17:25:38 raspberrypi satnogs-client[632]: 2019-08-06 17:25:38,221 - apscheduler.executors.default - INFO - Running job “post_data (trigger: interval[0:02:00], next run at: 2019-08-06 14:27:38 UTC)” (scheduled at 2019-08-06 14:25:38.173227+00:00)
Aug 06 17:25:38 raspberrypi satnogs-client[632]: 2019-08-06 17:25:38,230 - apscheduler.executors.default - INFO - Job “post_data (trigger: interval[0:02:00], next run at: 2019-08-06 14:27:38 UTC)” executed successfully
Aug 06 17:25:38 raspberrypi satnogs-client[632]: 2019-08-06 17:25:38,748 - apscheduler.executors.default - INFO - Job “get_jobs (trigger: interval[0:01:00], next run at: 2019-08-06 14:26:38 UTC)” executed successfully
Aug 06 17:26:38 raspberrypi satnogs-client[632]: 2019-08-06 17:26:38,173 - apscheduler.executors.default - INFO - Running job “get_jobs (trigger: interval[0:01:00], next run at: 2019-08-06 14:26:38 UTC)” (scheduled at 2019-08-06 14:26:38.155206+00:00)
Aug 06 17:26:38 raspberrypi satnogs-client[632]: 2019-08-06 17:26:38,683 - apscheduler.executors.default - INFO - Job “get_jobs (trigger: interval[0:01:00], next run at: 2019-08-06 14:27:38 UTC)” executed successfully
Aug 06 17:27:38 raspberrypi satnogs-client[632]: 2019-08-06 17:27:38,173 - apscheduler.executors.default - INFO - Running job “get_jobs (trigger: interval[0:01:00], next run at: 2019-08-06 14:28:38 UTC)” (scheduled at 2019-08-06 14:27:38.155206+00:00)
Aug 06 17:27:38 raspberrypi satnogs-client[632]: 2019-08-06 17:27:38,219 - apscheduler.executors.default - INFO - Running job “post_data (trigger: interval[0:02:00], next run at: 2019-08-06 14:29:38 UTC)” (scheduled at 2019-08-06 14:27:38.173227+00:00)
Aug 06 17:27:38 raspberrypi satnogs-client[632]: 2019-08-06 17:27:38,225 - apscheduler.executors.default - INFO - Job “post_data (trigger: interval[0:02:00], next run at: 2019-08-06 14:29:38 UTC)” executed successfully
Aug 06 17:27:38 raspberrypi satnogs-client[632]: 2019-08-06 17:27:38,752 - apscheduler.executors.default - INFO - Job “get_jobs (trigger: interval[0:01:00], next run at: 2019-08-06 14:28:38 UTC)” executed successfully
Aug 06 17:28:38 raspberrypi satnogs-client[632]: 2019-08-06 17:28:38,179 - apscheduler.executors.default - INFO - Running job “get_jobs (trigger: interval[0:01:00], next run at: 2019-08-06 14:29:38 UTC)” (scheduled at 2019-08-06 14:28:38.155206+00:00)
Aug 06 17:28:38 raspberrypi satnogs-client[632]: 2019-08-06 17:28:38,715 - apscheduler.executors.default - INFO - Job “get_jobs (trigger: interval[0:01:00], next run at: 2019-08-06 14:29:38 UTC)” executed successfully
Aug 06 17:29:38 raspberrypi satnogs-client[632]: 2019-08-06 17:29:38,174 - apscheduler.executors.default - INFO - Running job “get_jobs (trigger: interval[0:01:00], next run at: 2019-08-06 14:29:38 UTC)” (scheduled at 2019-08-06 14:29:38.155206+00:00)
Aug 06 17:29:38 raspberrypi satnogs-client[632]: 2019-08-06 17:29:38,219 - apscheduler.executors.default - INFO - Running job “post_data (trigger: interval[0:02:00], next run at: 2019-08-06 14:31:38 UTC)” (scheduled at 2019-08-06 14:29:38.173227+00:00)
Aug 06 17:29:38 raspberrypi satnogs-client[632]: 2019-08-06 17:29:38,225 - apscheduler.executors.default - INFO - Job “post_data (trigger: interval[0:02:00], next run at: 2019-08-06 14:31:38 UTC)” executed successfully
Aug 06 17:29:38 raspberrypi satnogs-client[632]: 2019-08-06 17:29:38,890 - apscheduler.executors.default - INFO - Job “get_jobs (trigger: interval[0:01:00], next run at: 2019-08-06 14:30:38 UTC)” executed successfully
Aug 06 17:30:38 raspberrypi satnogs-client[632]: 2019-08-06 17:30:38,186 - apscheduler.executors.default - INFO - Running job “get_jobs (trigger: interval[0:01:00], next run at: 2019-08-06 14:31:38 UTC)” (scheduled at 2019-08-06 14:30:38.155206+00:00)
Aug 06 17:30:39 raspberrypi satnogs-client[632]: 2019-08-06 17:30:39,019 - apscheduler.executors.default - INFO - Job “get_jobs (trigger: interval[0:01:00], next run at: 2019-08-06 14:31:38 UTC)” executed successfully
Aug 06 17:31:38 raspberrypi satnogs-client[632]: 2019-08-06 17:31:38,176 - apscheduler.executors.default - INFO - Running job “get_jobs (trigger: interval[0:01:00], next run at: 2019-08-06 14:32:38 UTC)” (scheduled at 2019-08-06 14:31:38.155206+00:00)
Aug 06 17:31:38 raspberrypi satnogs-client[632]: 2019-08-06 17:31:38,216 - apscheduler.executors.default - INFO - Running job “post_data (trigger: interval[0:02:00], next run at: 2019-08-06 14:33:38 UTC)” (scheduled at 2019-08-06 14:31:38.173227+00:00)
Aug 06 17:31:38 raspberrypi satnogs-client[632]: 2019-08-06 17:31:38,222 - apscheduler.executors.default - INFO - Job “post_data (trigger: interval[0:02:00], next run at: 2019-08-06 14:33:38 UTC)” executed successfully
Aug 06 17:31:38 raspberrypi satnogs-client[632]: 2019-08-06 17:31:38,742 - apscheduler.executors.default - INFO - Job “get_jobs (trigger: interval[0:01:00], next run at: 2019-08-06 14:32:38 UTC)” executed successfully
Aug 06 17:32:38 raspberrypi satnogs-client[632]: 2019-08-06 17:32:38,177 - apscheduler.executors.default - INFO - Running job “get_jobs (trigger: interval[0:01:00], next run at: 2019-08-06 14:33:38 UTC)” (scheduled at 2019-08-06 14:32:38.155206+00:00)
Aug 06 17:32:38 raspberrypi satnogs-client[632]: 2019-08-06 17:32:38,690 - apscheduler.executors.default - INFO - Job “get_jobs (trigger: interval[0:01:00], next run at: 2019-08-06 14:33:38 UTC)” executed successfully
Aug 06 17:32:42 raspberrypi satnogs-client[632]: 2019-08-06 17:32:42,154 - satnogsclient - INFO - Closing socket: <socket._socketobject object at 0x700db068>
Aug 06 17:33:07 raspberrypi satnogs-client[632]: 2019-08-06 17:33:07,006 - apscheduler.executors.default - INFO - Job “spawn_observer (trigger: date[2019-08-06 14:24:56 UTC], next run at: 2019-08-06 14:24:56 UTC)” executed successfully
Aug 06 17:33:38 raspberrypi satnogs-client[632]: 2019-08-06 17:33:38,181 - apscheduler.executors.default - INFO - Running job “get_jobs (trigger: interval[0:01:00], next run at: 2019-08-06 14:33:38 UTC)” (scheduled at 2019-08-06 14:33:38.155206+00:00)
