Observation 8668043: NOAA 15 (25338) - Image quality
Regarding Observation 8668043
Given my struggles with CubeSats, I’ve reverted to NOAA passes to check my installation. However, I don’t appear to be decoding NOAA images either. I can do this successfully just using an RTL dongle and laptop. I’ve checked the antenna - no issue. Am I missing a step somewhere?
Thanks again
Adrian
the metadata of that obs shows gain: null
that will most definitely not work, it needs to be set to a proper value.
this has been discussed many times and will be found with a search.
hope you will get it up and running ok.
