Observation 8563386: DJIBOUTI-1A (99027)
Regarding Observation 8563386
Hello ,
I’m part of the team that developed and currently operates the DJIBOUTI 1A satellite. As your observation, you are receiving very clean signals from our satellite. On our side, we receive very weak signals. We’d like to ask you for your setup so we can compare it with ours and see what’s wrong.
Thank you for your understanding.
There is a short description of the setup in:
https://network.satnogs.org/stations/3020/
Hello,
Thanks for your feedback. Yes, I saw that too. Is it possible to know a little more in detail?
Station 3020 setup
Radio:
driver=SDRplay
hardware=RSP1A
sdrplay_api_api_version=3.070000
sdrplay_api_hw_version=255
Satnogs Client:
“versions”: {
“satnogs-client”: “1.8.1”,
“gr-satnogs”: “2.3.5.0-1”,
“gr-soapy”: “2.1.3.1-1”,
“gnuradio”: “3.8.2.0-14”,
“satnogs-config”: “0.13.2”
“state”: {
“is-applied”: true,
“pending-tags”: null
“system”: {
“date”: “2023-12-05T13:14:41.228086+00:00”,
“distribution”: {
“RELEASE”: “11”,
“CODENAME”: “bullseye”,
“ID”: “Raspbian”
“pending-updates”: true,
“platform”: {
“system”: “Linux”,
“node”: “jim”,
“release”: “6.1.21-v8+”,
“configuration”: {
“satnogs_antenna”: “RX”,
“satnogs_gain_mode”: “Settings Field”,
“satnogs_other_settings”: “RFGR=1,IFGR=49”,
“satnogs_rx_bandwidth”: “200000”,
“satnogs_rx_samp_rate”: “250000”,
“satnogs_soapy_rx_device”: “driver=sdrplay”,
“satnogs_station_id”: “3020”,
