Regarding Observation 6729 …
$ sox satnogs_7097_2017-06-21T13-13-24.wav -esigned-integer -b 16 -r 11025 -t raw - | \
direwolf -B 1200 -b 16 -n 1 -r 11025 -q hd -t 0 -q h -q d -d p -d t -a 0 - \
> satnogs_7097_2017-06-21T13-13-24.txt
Dire Wolf version 1.4
Setting such a small audio statistics interval will produce inaccurate sample rate display.
Warning: Could not open ‘symbols-new.txt’.
The “new” overlayed character information will not be available.
ERROR - Could not open config file /home/alc/direwolf.conf
Try using -c command line option for alternate location.
Audio input device for receive: stdin (channel 0)
Audio out device for transmit: default (channel 0)
Channel 0: 1200 baud, AFSK 1200 & 2200 Hz, E+, 11025 sample rate.
[0.2] HB9CYA>CQ,RS0ISS*:<0x0d>
U frame UI: p/f=0, No layer 3 protocol implemented., length = 24
dest CQ 0 c/r=1 res=3 last=0
source HB9CYA 0 c/r=0 res=3 last=0
digi 1 RS0ISS 0 h=1 res=3 last=1
000: 86 a2 40 40 40 40 e0 90 84 72 86 b2 82 60 a4 a6 ..@@@@...r...`..
010: 60 92 a6 a6 e1 03 f0 0d `.......
[0.1] YU7RD>APRS,RS0ISS*:=4532.92N/01930.10E-Op.Vlado/QTH:Kula {UISS54}
U frame UI: p/f=0, No layer 3 protocol implemented., length = 69
dest APRS 0 c/r=0 res=3 last=0
source YU7RD 0 c/r=0 res=3 last=0
000: 82 a0 a4 a6 40 40 60 b2 aa 6e a4 88 40 60 a4 a6 ....@@`..n..@`..
010: 60 92 a6 a6 e1 03 f0 3d 34 35 33 32 2e 39 32 4e `......=4532.92N
020: 2f 30 31 39 33 30 2e 31 30 45 2d 4f 70 2e 56 6c /01930.10E-Op.Vl
030: 61 64 6f 2f 51 54 48 3a 4b 75 6c 61 20 7b 55 49 ado/QTH:Kula {UI
040: 53 53 35 34 7d SS54}
[0.1] YO8RAA-3>CQ,RS0ISS*:=4731.68N/02533.94Er73' Via Satellite
U frame UI: p/f=0, No layer 3 protocol implemented., length = 60
dest CQ 0 c/r=0 res=3 last=0
source YO8RAA 3 c/r=0 res=3 last=0
000: 86 a2 40 40 40 40 60 b2 9e 70 a4 82 82 66 a4 a6 ..@@@@`..p...f..
010: 60 92 a6 a6 e1 03 f0 3d 34 37 33 31 2e 36 38 4e `......=4731.68N
020: 2f 30 32 35 33 33 2e 39 34 45 72 37 33 27 20 56 /02533.94Er73' V
030: 69 61 20 53 61 74 65 6c 6c 69 74 65 ia Satellite
[0.1] ON4DA-6>CQ,RS0ISS*:73 de Dirk - ON4DA@amsat.org
U frame UI: p/f=0, No layer 3 protocol implemented., length = 51
source ON4DA 6 c/r=0 res=3 last=0
000: 86 a2 40 40 40 40 e0 9e 9c 68 88 82 40 6c a4 a6 ..@@@@...h..@l..
010: 60 92 a6 a6 e1 03 f0 37 33 20 64 65 20 44 69 72 `......73 de Dir
020: 6b 20 2d 20 4f 4e 34 44 41 40 61 6d 73 61 74 2e k - ON4DA@amsat.
030: 6f 72 67 org
[0.1] PE1NTN>CQ,RS0ISS*:=5229.98N/00449.43E-JO22jl - Wormer - pe1ntn@amsat.org
U frame UI: p/f=0, No layer 3 protocol implemented., length = 77
source PE1NTN 0 c/r=0 res=3 last=0
000: 86 a2 40 40 40 40 e0 a0 8a 62 9c a8 9c 60 a4 a6 ..@@@@...b...`..
010: 60 92 a6 a6 e1 03 f0 3d 35 32 32 39 2e 39 38 4e `......=5229.98N
020: 2f 30 30 34 34 39 2e 34 33 45 2d 4a 4f 32 32 6a /00449.43E-JO22j
030: 6c 20 2d 20 57 6f 72 6d 65 72 20 2d 20 70 65 31 l - Wormer - pe1
040: 6e 74 6e 40 61 6d 73 61 74 2e 6f 72 67 ntn@amsat.org
[0.2] RS0ISS>CQ:>ARISS - International Space Station
U frame UI: p/f=0, No layer 3 protocol implemented., length = 52
source RS0ISS 0 c/r=0 res=3 last=1
000: 86 a2 40 40 40 40 e0 a4 a6 60 92 a6 a6 61 03 f0 ..@@@@...`...a..
010: 3e 41 52 49 53 53 20 2d 20 49 6e 74 65 72 6e 61 >ARISS - Interna
020: 74 69 6f 6e 61 6c 20 53 70 61 63 65 20 53 74 61 tional Space Sta
030: 74 69 6f 6e tion
[0.2] YU7RD>APRS,RS0ISS*:=4532.92N/01930.10E-Op.Vlado/QTH:Kula {UISS54}
[0.2] IZ1BOH>APRS,RS0ISS*:[JN44JV]-73....for ALL,de FRANK (ITALY)<0x0d>
U frame UI: p/f=0, No layer 3 protocol implemented., length = 63
dest APRS 0 c/r=1 res=3 last=0
source IZ1BOH 0 c/r=0 res=3 last=0
000: 82 a0 a4 a6 40 40 e0 92 b4 62 84 9e 90 60 a4 a6 ....@@...b...`..
010: 60 92 a6 a6 e1 03 f0 5b 4a 4e 34 34 4a 56 5d 2d `......[JN44JV]-
020: 37 33 2e 2e 2e 2e 66 6f 72 20 41 4c 4c 2c 64 65 73....for ALL,de
030: 20 46 52 41 4e 4b 20 28 49 54 41 4c 59 29 0d FRANK (ITALY).
[0.2] YO8RAA-5>APU36Q,RS0ISS*:!4731.77N/02533.96EbI wantSKEDviaSATELLITEwith LOTW members,73<0x0d>
U frame UI: p/f=0, No layer 3 protocol implemented., length = 86
dest APU36Q 0 c/r=0 res=3 last=0
source YO8RAA 5 c/r=0 res=3 last=0
000: 82 a0 aa 66 6c a2 60 b2 9e 70 a4 82 82 6a a4 a6 ...fl.`..p...j..
010: 60 92 a6 a6 e1 03 f0 21 34 37 33 31 2e 37 37 4e `......!4731.77N
020: 2f 30 32 35 33 33 2e 39 36 45 62 49 20 77 61 6e /02533.96EbI wan
030: 74 53 4b 45 44 76 69 61 53 41 54 45 4c 4c 49 54 tSKEDviaSATELLIT
040: 45 77 69 74 68 20 4c 4f 54 57 20 6d 65 6d 62 65 Ewith LOTW membe
050: 72 73 2c 37 33 0d rs,73.
