Regarding Observation 6622259 …
Is my received signal just too weak, or why wasn’t it decoded?
Thanks
Thanks
SanoSat-1 seems to a tough one signal-wise, at least with the RTTY FSK transmitter. Looks like decoding has only been successful if you are running the satnogs-gr_satellites module but I could be mistaken on this.
Okay thanks for reply, i will consider to use the recommended module.
