Regarding Observation 658843 …
I added M2 support to my station and its been working fine. In the past I did do a satnogs update and had to go through the changes again to make it work. This time around I didnt do anything and its not working, or at least I cant tell but the waterfall is not right.
Question, when will the M2 decode be added to satnogs, its been around for a while.
Also where can I go to see revision updates and the changes that are made to satnogs.
Also is there a road map of enhancements or improvements that you have coming down the pipe.
