I have several passes where the data seems to be visible and audible, and on frequency, but doesn’t decode (I do get decodes from some satellites). Journalctl doesn’t show anything about decoding. Is there any debug data that I can look for or turn on to determine why?
PE0SAT has linked to an observation on my station. I am also using gr_satellites to decode packets. And all decodes for this satellite were done by it. You can see this because the file names of the packets end in _g0 or _g1 etc. See this post on how to get gr_satellites added to your station: https://community.libre.space/t/install-the-satnogs-gr-satellites-addon-and-use-your-station-more/
