Observation 6111502: GRIFEX (40379)
Regarding Observation 6111502 … Looks like the frequency was shifted a bit
Can you please also have a look at your SDR LO, if this is a RTL-SDR look at Kalibrate.
kalibrate v0.4.1-rtl, Copyright (c) 2010, Joshua Lackey
modified for use with rtl-sdr devices, Copyright (c) 2012, Steve Markgraf
Usage:
	GSM Base Station Scan:
		kal <-s band indicator> [options]
	Clock Offset Calculation:
		kal <-f frequency | -c channel> [options]
Where options are:
	-s	band to scan (GSM850, GSM-R, GSM900, EGSM, DCS, PCS)
	-f	frequency of nearby GSM base station
	-c	channel of nearby GSM base station
	-b	band indicator (GSM850, GSM-R, GSM900, EGSM, DCS, PCS)
	-g	gain in dB
	-d	rtl-sdr device index
	-e	initial frequency error in ppm
	-E	manual frequency offset in hz
	-v	verbose
	-D	enable debug messages
	-h	help
nice, will check, thanks!
I tried this and experimentally I’ve picked up 1.6kHz as a seemingly reasonable offset, at least when scanning the GSM / 900MHz band with kal. I’ve entered it now into the SatNOGS configuration, but that should only make frequency configuration a bit more precise, right? I.e. just place the 0 mark of the waterfall a bit more exactly. Maybe it will improve some data decoding, but hardly significantly? And otherwise it shouldn’t actually improve the general reception quality?
Share your satnogs config to see what PPM value you have configured
oh, none, I thought I should use that for LO_OFFSET
Ok, I read in SatNOGS Client Setup - SatNOGS Wiki that I shouldn’t use LO_OFFSET. Since 1.6kHz was the offset suitable for 900MHz, should I specify a PPM_ERROR value of 2 then?
hm, but looking at my LUSAT captures, its signal didn’t become closer to 0 after this PPM adjustment, in fact it became a bit further from it, trying to change the sign…
kal give you a proposal most of mine PPM values are negative, and you can only use integer values.
As an example: kal ppm proposal is -1.3 then you will configure SATNOGS_PPM_ERROR="-1"
An other example: kal ppm proposal is -1.7 then you will configure SATNOGS_PPM_ERROR="-2"
Here a run I did on one of my systems:
kal -s GSM900 -g 0
Found 1 device(s):
  0:  Generic RTL2832U OEM
Exact sample rate is: 270833.002142 Hz
[R82XX] PLL not locked!
kal: Scanning for GSM-900 base stations.
GSM-900:
    chan:    5 (936.0MHz + 1.834kHz)    power:   32080.79
    chan:    8 (936.6MHz + 2.414kHz)    power:   29299.42
    chan:   10 (937.0MHz + 2.587kHz)    power:   28248.30
    chan:   45 (944.0MHz + 2.894kHz)    power:   23174.72
    chan:   46 (944.2MHz + 2.582kHz)    power:   30341.13
    chan:   88 (952.6MHz + 1.963kHz)    power:   39869.48
    chan:  100 (955.0MHz + 2.569kHz)    power:   40559.64
...chan 124
Run multiple times to take temperature influences into account, and at the end use the average.
while true
do
  kal -c 100 -b GSM900 -g 0
  sleep 2
done
Found 1 device(s):
kal: Calculating clock frequency offset.
Using GSM-900 channel 100 (955.0MHz)
Tuned to 955.000000MHz (reported tuner error: 0Hz)
average		[min, max]	(range, stddev)
+ 2.495kHz		[2452, 2531]	(79, 19.737494)
overruns: 0
not found: 0
average absolute error: -2.613 ppm
So at the end I use -2.613 and set SATNOGS_PPM_ERROR="-3"
nice, thanks! I tried two different channels, it was about 1.3 for one and 1.1 for another, so I’m using 1 for now
